Old 04-23-2012, 11:54   #1 (permalink)
Member: 629558
asus v66 full back-up badly need
asus v66 full back-up badly need.................
thanks......
Old 04-23-2012, 16:33   #2 (permalink)
Member: 148515
hello!
please, at least let us know software version
Old 04-24-2012, 04:41   #3 (permalink)
Member: 629558
logs......successfully format but dead.
==== [4/23/2012 9:15:56 PM] ====
COM19 [VCP0] selected
module v3.51
Action: reset settings ("format ffs")
Model: Asus-V66
Checking data, wait...
19200 autodetect
Initializing [6219:8A01]...
CPU: MT6219
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6219,E01
Date: 2004.06.18
Version: 1.2.1.4
Version: V66-ASUS-PH-R103-1-V4.5.0
Version: V61_HW
65 byte(s) read
imei: 13579024681122
warning: current phone imei is incorrect !
It's need to repair imei for correct phone functionality !
connection Ok
building list...
done
items to clear: 176
warning: wrong packet cs
items cleared: 176 of 176
building list...
done
items remains: 0
Finished, time used: 42 sec
Remove/Install battery now !
flashing successfully but still dead
==== [4/23/2012 9:26:46 PM] ====
module v3.51
Device: Asus-V66
Action: write flash
"smart write" active
"format ffs" active
write: Firmware
Asus-V66_V66-ASUS-PH-R103-1-V4.3.0_Aug-30-2005_En_Cn.B0M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6219
boot packet size: 0400
Boot Done
====> Initialize ...
flash: 01227E22202200:29EA0000000000
flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
otp offset: 00000000
Initialize Done
====> Set baud ...
230400
Set baud Done
====> Initialize bootcode ...
interesting cpu type found
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
warning: rom info information not found, possible reasons:
- old firmware type w/o rom info information
- empty (completely or partially erased) flash chip
- damaged firmware
- damaged hardware (bad soldered or damaged flash chip)
> if phone works fine just ignore this warning <
ffs/eeprom address can not be detected, value from database assigned: 00E00000/00200000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
firmware patch (sp-lock #1)...
not required
firmware patch (sp-lock #2)...
not required
Special operation Done
====> Write ...
Area: Firmware
Write: Firmware
usb bootloader (file) is absent
sec info (fast) detection...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 14 min 6 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
WARNING ! Settings will be cleared, user data erased, Imei set to default value !
Make flash backup before this procedure !
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 11-29-2010 18:04
needed pinout for carkit(N61xx) mobileinfo Nokia Hardware & Hardware-Repair Area 1 12-27-2006 10:20
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 1 06-02-1999 16:23
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 05-26-1999 11:35
Page generated in 0.22619 seconds with 11 queries
