Old 10-17-2008, 20:01   #1 (permalink)
Super Moderator
Member: 813309
Thanks Meter: 1,912
FAILURE UNLOCK ALCATEL S520A I had Q EARNING DEAD WITH POLAR BOX
HERE THE LOG
==== log: [16/10/2008 13:33:19] ====
COM19 [VCP0] selected
module v2.36
Device: Alcatel-OT-S520X, S520A
Checking data, wait...
Action: write NOR flash
"smart write" active
"format ffs" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
Boot...
19200 fixed
Connecting, wait...
Initializing[6225:8A03:8A00]...
CPU: MT6225
chip: 0001:2703:A00C
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 01227E22442200:18E59F00000000
flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000 0004x008000] 16Mb
Initialize Done
Set baud...
460800
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.A5 72578A.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN_B8A8FFD4].rpl
identification#1 detection finished
device-id: A572578A
identification#1 protocol ver: 05
ver. sw1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN
ver. sw2: MAUI.06B.W07.28.SP1.V34, 2B005747
ffs offset/size: 00C00000/00400000
detect device identification#2...
detect device identification#2 finished
sim-lock status: enabled
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
original imei: 01143900053292
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
security area (code #1) calculation...
done
file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\syste m_log_A572578A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAU I_06B_W07_28_SP1_V34.BIN_B8A8FFD4_20081016-133359.B0X.bin
Area: Firmware
Write: Firmware
security area (code #3, part #2) calculation...
customization: CD44GD00
done
Write: security area (code #3, part #2)
error: wrong answer: C4
error: flash write error: 00BFC000:00002000
error: wrong answer: C7
error: wrong answer: 3B
00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 0000000000
error: can't write required area
security area (code #3, part #2) calculation failed
Write Done
Finalization...
formatting...
error: wrong answer: 3B : wrong answer after chip id request
error: no any expected answer: wrong answer after chip cfi request
error: no any expected answer: wrong answer after chip id request
Finalization Fail
file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\syste m_log_A572578A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAU I_06B_W07_28_SP1_V34.BIN_B8A8FFD4_20081016-134236.B0X.bin
Finished, time used: 552 sec
Remove/Install battery now
Old 10-17-2008, 20:05   #2 (permalink)
Super Moderator
Member: 813309
Thanks Meter: 1,912
Lords kashans infinity and support team
Old 10-17-2008, 20:21   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Is it so urgent problem that you have posted question at 20-01 and then asked again in 20-05 ?
Old 10-17-2008, 20:28   #4 (permalink)
Member: 130995
Yes, I see it's urgent so here is my advice:
Any urgent job should be done with 100% (completely charged battery, in other case you can see write problems at end of process.
So try to interrupt message writing and charge battery completely.
Then flash phone again.
if problem still exist with completely chrged battery you must open phone and check it's hardware (f.e. reball flash chip).
Thank you for your understanding.
Hope next time you will be more careful and you will wait answer with patience instead of spam forum with useless posts.
Old 10-17-2008, 21:27   #5 (permalink)
Super Moderator
Member: 813309
Thanks Meter: 1,912
only that it was not the drummer
Old 10-17-2008, 21:28   #6 (permalink)
Member: 20666
Thanks Meter: 3
HERE THE LOG
module v2.36
"format ffs" active
write: Firmware
skip: Customization
skip: Eeprom/ffs
Boot...
19200 fixed
Connecting, wait...
CPU: MT6225
Boot Done
Initialize...
Initialize Done
Set baud...
460800
Set baud Done
device-id: A572578A
Write...
done
Area: Firmware
Write: Firmware
done
Write Done
Finalization...
formatting...
Finalization Fail
You can repair this with Polar Box flashing again
Tested by me
Regards
Old 10-17-2008, 21:30   #7 (permalink)
Super Moderator
Member: 813309
Thanks Meter: 1,912
I did look at the title
Old 10-17-2008, 21:31   #8 (permalink)
Super Moderator
Member: 813309
Thanks Meter: 1,912
but thanksbut thanks man
Old 10-18-2008, 22:03   #9 (permalink)
Member: 130995
@Philips
Just for your information: here is Infinity-Box support forum so please, let\'s talk here about Infinity-Box.
As about phones repair: in compare with other tools you are able to repair EMPTY-BOARD Alcatel phones (phones with completely empty or erased flash chip) with Infinity-Box.
Alcatel of 206 dead with polar [ANSWERED] kopsa2005 PolarBox 3 11 08-01-2014 11:35
Polar team support, alcatel died after release with polar box ..... [ANSWERED] boliargsm PolarBox 3 6 02-06-2010 08:06
GB 102 Dead with Polar BOX? [SOLVED] Tetouan Gsm PolarBox 3 14 01-19-2010 13:10
Alcatel s920 successfully unlocked with polar box dasuza PolarBox 3 3 10-28-2008 21:16
Page generated in 0.22596 seconds with 9 queries
