02-07-2017, 16:59 | #1 (permalink) |
No Life Poster Join Date: Mar 2014 Location: Romania
Member: 2157664 Status: Offline Thanks Meter: 43 | asus z00ed frp reset can t reset frp on asus z00ed based on qualcomm snapdragon 410 msm8916. Card found : B2387FA5 , v0135 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.09 Operation : Identify [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 1C20B20C ID_BLOCK_I : 007050E1 ID_BLOCK_L : 996B01FD58C6F3FEA99E765F98E3735B ID_BLOCK_L : FB8A3497980BB330D52075A2A04F5962 Use CM2 Internal Loader Error : Loader send failed! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Reset Settings [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 1C20B20C ID_BLOCK_I : 007050E1 ID_BLOCK_L : 996B01FD58C6F3FEA99E765F98E3735B ID_BLOCK_L : FB8A3497980BB330D52075A2A04F5962 Use CM2 Internal Loader Error : Loader send failed! Check cable, connection and drivers! Reconnect Power/Cable! pls help! |
02-07-2017, 17:34 | #2 (permalink) |
Freak Poster Join Date: Jan 2007
Member: 427167 Status: Offline Sonork: 100.1670875 Thanks Meter: 48 | Latest version 1.10, but this model not supported in this version too, may be it will be support in next version. Try find FRP bypass method for this model using Google. |
