05-09-2016, 20:29 | #1 (permalink) |
No Life Poster Join Date: Dec 2015 Location: hossting
Member: 2501288 Status: Offline Thanks Meter: 328 | ASUS Z00VD unlock boot loader failed 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 165 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! Operation : FastBoot : Unlock BootLoader [ v1.47 ] Power Off Phone , re-connect battery , Insert USB cable! Wait for phone... Phone found! [ 165 ] Sync... Protocol : 0.5 Device : AW806 Storage : eMMC BootLoader : Locked Warranty : Not tampered ( Under Warranty ) Secure : Enabled ExtraStat : FB Load Supported! ERROR : FAIL Unlock operation is not allowed Operation Failed Elapsed: 00:00:32 Reconnect Power/Cable! |
The Following User Says Thank You to Steve-1 For This Useful Post: |
05-10-2016, 08:07 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Not supported. Br. Infinity Box Support Team. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
05-10-2016, 18:48 | #3 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
05-10-2016, 19:02 | #5 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | You need use SD card mode update, for example. I got few phones and explore them for add on support. |
The Following 2 Users Say Thank You to JayDi For This Useful Post: |
