12-07-2017, 15:27 | #1 (permalink) |
No Life Poster Join Date: Aug 2006
Member: 334773 Status: Offline Thanks Meter: 92 | asus zoold 7.1.1 frp lock 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Reset Settings [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 430 [MSM8937] ID_BLOCK_S : 02A54FED ID_BLOCK_I : 0004F0E1 ID_BLOCK_E : 2016A239 ID_BLOCK_L : 9B038D805A6DE6BDB9AC5D9FA78D03CB ID_BLOCK_L : A4060C4299161E73668BCE20BAB4A786 Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! |
12-07-2017, 15:38 | #3 (permalink) |
Member: 334773 Status: Offline Thanks Meter: 92 | ji tried not success give some solution Elapsed: 00:00:03 Operation : Reset FRP [ v1.03 ] Mode : Remove ASUS GENERIC FRP Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! ADB Enable FAIL! Done! Elapsed: 00:00:06 Last edited by scorpion_bashee; 12-07-2017 at 15:43. |
