06-26-2017, 14:26 | #1 (permalink) |
No Life Poster Join Date: Oct 2010 Location: INDIA (WEST BENGAL)
Member: 1426012 Status: Offline Sonork: ICQ#618627674 Thanks Meter: 886 | Asus_z00vd -read flash ok formate/fs ok write flash error.unable to write flash Code: Finish at : [23-Jun-17 / 8:38:04 PM] Scatter Load Ok , BaseBand : MT6580 , Project : aw806 , Storage : EMMC Files found : 12 , Set to Flash : 11 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : asus Device Model : ASUS_Z00VD Device CPU : MT6580 Device IntName : WW_Phone Device Version : 5.1 Device Compile : 25-Aug-16 1:24:40 PM Device Project : WW_Phone-12.1.0.51-20160825 Device ExtInfo : ASUS_Z00VD Ready to Flash! Start at : [23-Jun-17 / 8:39:00 PM] Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4841473265050709A8E4BE32CB Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x80000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e2GA [eMMC] : FLASH_CID : 90014A4841473265050709A8E4BE32CB [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB800000 [eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB] DEV RID : 0xD5575D40C74799BDD2572CB618C69131 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6580 , Project : aw806 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled Switching to HSUSB HSUSB Init Ok BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3840 mV BL : BatteryLevel Ok ========================= Start ========================= 24-Jun-17 / 11:38:18 AM ========================================================= Card found : S/N : AD016952 , v0136 Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6580 , Project : aw806 , Storage : EMMC Files found : 12 , Set to Flash : 11 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : asus Device Model : ASUS_Z00VD Device CPU : MT6580 Device IntName : WW_Phone Device Version : 5.1 Device Compile : 4/4/2016 8:45:43 AM Device Project : WW_Phone-12.1.0.47-20160404 Device ExtInfo : ASUS_Z00VD Ready to Flash! Start at : [24-Jun-17 / 11:39:39 AM] Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4841473265050709A8E4BE32CB Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x80000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e2GA [eMMC] : FLASH_CID : 90014A4841473265050709A8E4BE32CB [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB800000 [eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB] DEV RID : 0xD5575D40C74799BDD2572CB618C69131 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6580 , Project : aw806 , Storage : EMMC Setting : Flash Pre-Erase : Off ( Write Flash Only ) Setting : AFF verify : Disabled Setting : HW verify : Disabled Switching to HSUSB HSUSB Init Ok BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 3971 mV BL : BatteryLevel Ok [SECURE] : Break flashing by user request Operation Failed Elapsed: 00:39:59 Reconnect Power/Cable! |
