Old 05-14-2017, 15:44   #1 (permalink)
tejas243404's Avatar
Member: 725038
Sonork: 100.1675584
Thanks Meter: 288
oppo a57 not read info cm2 n
oppo a57 not read info cm2 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 435 [MSM8940] ID_BLOCK_S : EF61080A ID_BLOCK_I : 0006B0E1 ID_BLOCK_L : 24FA7BC1F9EF8EA7E4E6F868F7BEF994 ID_BLOCK_L : C7FE6760DB83009A93AC616C40139912 Use CM2 Internal Loader
Old 05-14-2017, 15:50   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Use latest CM2QLM module : v1.11
Old 05-16-2017, 20:35   #3 (permalink)
Member: 725038
Sonork: 100.1675584
Thanks Meter: 288
hiii
all rady this ver use sir same prob
Old 05-16-2017, 20:56   #4 (permalink)
JayDi's Avatar
Member: 462970
Check cable and battery.
Repeat operation.
Also use logs, instead of unformatted text.
Page generated in 0.13855 seconds with 8 queries
