06-04-2008, 08:42 | #1 (permalink) |
Freak Poster Join Date: Feb 2008 Location: Trichy, Tamil Nadu Age: 49
Member: 701311 Status: Offline Thanks Meter: 55 | Attention Infinity Team, vodofone225 write failed I also tried all firmwares from supprt area and remains the same. Here is the one of the log I tried: Loading file v.02... ZTE-225_main_EH-HU-P108A2V1.0.0B03__VDF-P108A2B07-Hu-HU03_g3dBV2.0.B1M.bin loaded COM14 [VCP0] selected Device: ZTE-225, Vodafone-225 Checking data, wait... Action: flash write Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 00BF:7353 Connecting Done Check hardware... flash chip supported Check hardware Done Check parameters... Check parameters Done backup critical area... backup critical area Done Check memory... Check memory Done Write... Erasing: Firmware Writing: Firmware repair write error [00401000]... error: write failed[00400000] Write Failed Finished, Remove/Install battery now ! Time used: 31 sec Please help me Thanks in advance |
06-04-2008, 15:23 | #3 (permalink) |
Member: 701311 Status: Offline Thanks Meter: 55 | Attention Infinity Team, vodofone225 write failed Thanks Team for ur reply i tried to Huawei T 201 But all in vain. Here is the log Loading file v.02... ZTE-225_Main_VDF-P108A2B06-ArFr-EG04_g3dBV2.0_May-29-2007.B1M.bin loaded Loading file v.02... ZTE-225_ffs_ZH_P108A9V1.0.0B05.B1S.bin loaded COM14 [VCP0] selected Device: Huawei-T201 Checking data, wait... Action: flash write Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... error: can't run main loader: Finished, Remove/Install battery now ! Time used: 5 sec I hope Team Will help Me soon regards Thanks |
06-05-2008, 05:25 | #4 (permalink) | |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Quote:
It's so high speed for this E-Gold derivative phone ... same problem will appear sometime ( mostly on Vodafone ( ZTE ) 227 i was count ) if you use and other tools like MT-Red or Furious on this baud rate... so - easy is to make it lower - atleast there not so big flash image . | |
06-05-2008, 15:58 | #5 (permalink) | |
Member: 701311 Status: Offline Thanks Meter: 55 | Quote:
I tried also changing baud rate but still same problem. Please any one help me regards Thanks in advance | |
Attention infinity team LG CDMA RDxxxx models | gunjan1 | Infinity-Box | 4 | 07-26-2009 10:02 |
attention infinity team | nadeem ahmad | Infinity-Box | 2 | 04-22-2009 17:09 |
Infinity team attention please | prime_master786 | Infinity-Box | 7 | 11-19-2008 15:14 |
Infinity Team Give Attention | RUVAIZ | Infinity-Box | 2 | 02-20-2008 15:57 |
Attention Infinity Team.....can You Unlock C115? | bengrippin | Infinity-Box | 6 | 08-10-2006 19:43 |
