Old 02-20-2010, 10:24   #1 (permalink)
pulsecom's Avatar
Member: 640386
Thanks Meter: 5
attention inifinity team
flashed my 5610 china with afile found in support site but now not switching on here si the log
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: write flash
"smart write" active
write: Firmware
MT25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08_ 12_F1__Nokia-5610_16m_En_Ru_Fr_De_Th_Vn_Tr_Ar.B0M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:C603:000F
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 01227E22202200:18E59F00000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info detection finished
rom info ver: 04
sw version: MT25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08_ 12_F1.BIN
project-id: MAUI.GEMINI.W08.12.F1, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: MT25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08_ 12_F1__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\MT25_GEMINI_PCB01 _GPRS_MT6225_S00.MAUI_GEMINI_W08_12_F1__ffs_201002 20-100802.B0E.bin
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
sec info (fast) detection...
usb bootloader (file) is absent
startup code area #1 check...
startup code area #1 fixed
detecting startup code area #2...
startup code area #2 is absent
Area: Firmware
Write: Firmware
Write Done
====> Finalization ...
Finalization Done
Finished, time used: 25 min 0 sec
Remove/Install battery now !
please help!!!
Old 02-20-2010, 10:38   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
by any chance you have original backup saved?
Old 02-21-2010, 21:16   #3 (permalink)
pulsecom's Avatar
Member: 640386
Thanks Meter: 5
yes i do what should i do?
for inifinity team gily1 Infinity-Box 2 12-01-2008 19:35
please help me inifinity team taleb_nazari Infinity-Box 1 08-15-2008 20:46
please help me INIFINITY TEAM taleb_nazari Infinity-Box 5 05-24-2008 20:44
inifinity team please help taleb_nazari Infinity-Box 2 05-11-2008 22:19
For inifinity team marmouta Infinity-Box 0 12-02-2006 23:13
Page generated in 0.19040 seconds with 9 queries
