01-08-2018, 04:59 | #1 (permalink) |
Freak Poster Join Date: Feb 2014
Member: 2130320 Status: Offline Sonork: [email protected] Thanks Meter: 9 | attila mate pro unlock and repair solution 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:22 Reconnect Power/Cable! |
01-08-2018, 05:00 | #2 (permalink) |
Member: 2130320 Status: Offline Sonork: [email protected] Thanks Meter: 9 | [QUOTE=harvindar;12890417]Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:22 Reconnect Power/Cable! Operation : SP Unlock [ v1.58 ] Mode : Read Codes 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! |
01-08-2018, 05:53 | #3 (permalink) |
No Life Poster Join Date: Mar 2016 Location: Ukraine
Member: 2550141 Status: Offline Thanks Meter: 1,115 | [QUOTE=harvindar;12890419] Quote: download firmware, unpack and open scatter on flash tab, try this and post log https://fex.net/get/275855852355/199747404 |
