04-01-2008, 12:36 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: ABouSHaDy Age: 48
Member: 200717 Status: Offline Sonork: 100.1580056 Thanks Meter: 793 | auther V-TOUCH unlocked rapport pinfinfer software version: 1.05 searching adapter at COM2... adapter found, version: 2000 pins: 14 power cycles: 1 activation cycles: 7 power control: via adapter power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... CPU: MT6226 result: Rx:13 Tx:6 time required: 89 sec Power On ! rapport infinty team COM2 [VCP0] selected Device: Modelabs V-Touch Virgin Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: unlock unlock method: standard fast Unlock procedure can be faster if you skip eeprom area backup procedure. Do you want to disable eeprom backup ? eeprom backup enabled Boot... Press and HOLD Power button now ! 19200 Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 chip: 0031:407A:7F39 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 89881500010001:89881500000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Identification... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .............. warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished reading [eeprom]... file saved: C:\Program Files\InfinityBox\MModule\backup_eeprom_20080401-142520.B0E.bin flash: 89881500010001:89881500000000 Identification Done Manipulation... .................................................. . lock area found Manipulation Done Finalization... detecting additional parameters... ...................... flash: 89881500010001:89881500000000 flash: 89881500010001:89881500000000 Write: area 0/1 .......................................... additional parameters detected Ok Finalization Done Write... flash: 89881500010001:89881500000000 flash: 89881500010001:89881500000000 Write: lock-area-1 Write Done Finished, time used: 134 sec Remove/Install battery now ! |
HTC Touch Unlocking free | cellsolution | HTC & PDA WM( With Touchscreen) | 12 | 07-20-2007 07:26 |
anyone gotone touch unlock for T191??? | unlockgod | Motorola ODM | 0 | 01-10-2002 17:21 |
Gd52,92,93 One Touch Unlock No Risk | !!!TaaTTalTi!!! | Panasonic | 5 | 12-29-2001 11:37 |
Nokia FLASHER + one touch UNLOCKER. | Koci | Main Sales Section | 0 | 10-25-2001 08:21 |
