Old 03-14-2008, 17:52   #1 (permalink)
dannyogolo's Avatar
Member: 18200
Sonork: 100.1608286
Thanks Meter: 82
Auto PinFinder Power Problem
This box seems ok to me, but as with all boxes, there are a few phones that it doesnt work ok.
There are a few China phones that it cannot power. That is to say these phones comes up with battery, but not with pinfinder power cables.
Its not a matter of connecting the cables correctly, the cables are always well connected (the batteries have the "+" and "-" indicators and its almost impossible to mistake them. Also the indicator red light behind the pin finder remains on while i try to power phone (showing that the polarity is correct).
Maybe support should look at making it work with phone battery as well, or is there a way out ?
Old 03-14-2008, 18:21   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,456
Please, download latest PinFinder manual: http://www.infinity-box.biz/download..._PinFinder.pdf
Please, see page 18: Automatic pinout detection: Troubleshooting
I hope you can solve at least 99% of possible problems (especially with 8, 12, 14, 15 pins cables) with this instruction.
One more link: http://www./showthread.php?t=512662
Old 03-14-2008, 18:23   #3 (permalink)
Member: 170531
Thanks Meter: 8
this finder dont need to power on mobile ,its enugh give power for cpu and power ic to be can serach pinout .only when you make serach by finder need to stay press power key mobile untill find him.
if not find that mobile so your mobile maybe not mtk .
Old 03-14-2008, 22:13   #4 (permalink)
Member: 148515
Thanks Meter: 16,162
hello!
some uniboxes have very small output voltage on pin1.
Also 0,7 volts is dropping on transistor which swith power to phone.
so at the end we get voltages below 3,7 volts which is not enough to power On phone
if you have on pinfinder output voltage below 3,7v- please modify your unibox
there must be diode removed and set shortcut.
Where is located this diode you can find in pin finder user manual in troubleshooting section
Old 03-28-2008, 10:04   #5 (permalink)
navin71's Avatar
Member: 101891
Thanks Meter: 277
sir i just buy an infinity auto pin finder box can u please guide me how to use this (is there any installation cd come with this box) i have infinity box too
thanks
Old 03-28-2008, 11:09   #6 (permalink)
Member: 130995
thanks
Hello,
Information is here: http://www.infinity-box.biz/index.ph...infinder&lg=en
Read manual and pictures here: http://www.infinity-box.biz/download..._PinFinder.pdf
See video here: http://www.infinity-box.biz/download...nder_video.rar
Old 03-29-2008, 17:54   #7 (permalink)
navin71's Avatar
Member: 101891
Thanks Meter: 277
sir i have connected auto pinfinder to the pc with infinity box but while connecting it shows error like this
dongle is not activated for current software module
curent dongle activation lavel 0001
required dongle activation lavel 0011
download lattest dongle manager from support area
but when connecting through dongle manager it shows like this:-
----------Process started:10:17:20 PM----------
Locating Emeralda server...
Emeralda server#1 address found.
Connecting to Emeralda server#1...
Server connection successfully established.
S/N: *********Firmware: *****
Authenticating on server...
Authentication successfull.
Checking upgrade client version...
Your upgrade client is up-to-date.
Checking Dongle Identification...
Dongle Identification checked.
Activating module...
Module check error: Server reported error:[0044] Module S/N is already registered. Don't try more !
Old 03-29-2008, 21:01   #8 (permalink)
Member: 148515
hello!
need same log file but with full dongle detales to mailbox: [email protected]
Old 03-29-2008, 22:14   #9 (permalink)
mansi's Avatar
Member: 8664
Sonork: 100.1573507
Thanks Meter: 56
@dannyogolo
maybe your phone is not MTK based, maybe its spreadtrum or something else. [which you cant auto detect pinouts] with standard cables come with pinout finder.
one small advice: open phone and check CPU type [info is writen on cpu] if its MTK or not.
Mansi
Old 03-30-2008, 18:30   #10 (permalink)
navin71's Avatar
Member: 101891
Thanks Meter: 277
hello!
Thanksssssssssssssssssssssssssssssssssssssssss PIN FINDER IS ACTIVATED
THE GREAT SUPPORT I EVER SEEN
THANKS AGAIN INFINITY TEAM
q.:- can rx tx can be find out from dead set ?
q;- is it necessary to connect +ve and -tve wire (mean can we used battery instead of wire)
Old 03-30-2008, 18:39   #11 (permalink)
Cheater -Don't Deal with him-
::gsmcoder::'s Avatar
Member: 172434
Sonork: 100.161280
Thanks Meter: 574
to me, pinout finder usage is not traumatic..................
Old 03-30-2008, 19:37   #12 (permalink)
Member: 148515
hello mr. navin71!
please read user manual, there is all questins answered:
Old 03-31-2008, 05:41   #13 (permalink)
Faisal_Computer's Avatar
Member: 151871
Thanks Meter: 71,414
One Qua.
when i try to connect mobile with BOX power its works fine with 80% mobiles and when i insert bettery or try to use Power Supply ( not from Box ) its gave this
software version: 1.06
cable type: 1x8 (L8A)
platform: MT6205, MT6217-MT6228
searching adapter at COM7...
adapter found, version: 2000
pins: 8, plain
power cycles: 1
activation cycles: 7
power-off delay: 20
start Rx/Tx: 1/1
Loading configuration...
Initializing...
Press and HOLD phone Power button now !
detecting pins...
error: boot initialization step-2 failed: A0
19200
19200
19200
19200
19200
19200
19200
19200
19200
19200
19200
19200
19200
failed to detect pins
time required: 28 sec
Power Off !
so is this mean that we must use power from box ?
and also some mobile can't power up even pinout finder find pins for example 2 or 3 days ago i got Lg Kg200 pinout finder detect pins ( power from BOX ) and i need to rebuild IMEI on power from box its can flash but when i try to rebuild imei mobile not powering up can you advice me how to solve this type of problems , on the box +tv i got 5 volts and works fine just i got these type of problems
Faisal_Computer
Old 03-31-2008, 06:05   #14 (permalink)
asad_nomy7's Avatar
Member: 570093
Thanks Meter: 1,019
bro faisal i think the power cable from the box work as GND pin also.and when we connect it other power source its not have GND pin then not detect RX/TX.
Old 03-31-2008, 06:58   #15 (permalink)
milankumardoshi's Avatar
Member: 135200
Sonork: 100.1594691
Thanks Meter: 33
problem detecting rx tx
sir output#2 of pinfider has rj45 but the power terminal was given with 10 pin jack with 10 wires inside does it cause some problem.i get output 5 v
Infinity Box + Auto Pinfinder Most powerful GSM Device with ALL FREE UPDATES !!!! Infinity-Box Main Sales Section 0 08-13-2008 18:21
Pinfinder Adaptor have powering problem .. Gsm-W Infinity-Box 18 08-03-2008 02:57
Auto Pinfinder Problem asad_nomy7 Infinity-Box 10 05-24-2008 12:03
Auto pin finder power problem cellbhai Infinity-Box 6 02-25-2008 12:08
SGH-V200 auto power problem ranjit2003 Samsung Hardware Repair 3 08-20-2006 21:53
Page generated in 0.44980 seconds with 8 queries
