07-11-2008, 22:48 | #1 (permalink) |
Major Poster Join Date: Mar 2006
Member: 252848 Status: Offline Thanks Meter: 2 | AVVIO 103A unable to unlock!!!! here i will post the download link of the 2 backup phone i have in my hands. one is generic unlocked and the other is the one that is unable to unlock for some reason. http://rapidshare.com/files/12872479..._103a.rar.html http://rapidshare.com/files/12872479..._103a.rar.html please let me know if you need anything else in rder to get solution for this problem. Thank you Infinity team for GREAT SUPPORT PLEASE HELPPPP. Best Regards aikon2000 |
07-12-2008, 10:29 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much ! Please, try to flash your Movistar phone with Avvio-103A_G1.0_C00.76_P192_I7880F_0714B01_V11CNx_Nov-30-2007_Generic_ver2.B1M.bin file from Infinity-Box support area and then try to unlock it. Make backup before this operation for emergency case ! Let\'s see results. |
07-13-2008, 18:00 | #3 (permalink) |
Freak Poster Join Date: Sep 2006
Member: 357413 Status: Offline Thanks Meter: 17 | hello friends try flashing the flash mentioned but I get this error that is what will be happening COM7 [Serial2] selected Device: Avvio-103A Checking data, wait... Action: flash write Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:22C4 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Archivos de programa\InfinityBox\Pana01\Avvio-103A_eeprom-sta_20080712-115558.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Archivos de programa\InfinityBox\Pana01\Avvio-103A_eeprom-sec_20080712-115602.B1E.bin reading [eeprom-complete]... file saved: C:\Archivos de programa\InfinityBox\Pana01\Avvio-103A_eeprom-complete_20080712-115610.B1E.bin backup critical area Done Check memory... Check memory Done Write... Erasing: Firmware error: set erase range error: erase failed: 00200000 Write Failed Finished, Remove/Install battery now ! Time used: 35 sec |
07-13-2008, 18:14 | #4 (permalink) |
Member: 357413 Status: Offline Thanks Meter: 17 | I friend again to support the infinity of this when I get what I want to unlock COM7 [Serial2] selected Device: Avvio-103A Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:22C4 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Archivos de programa\InfinityBox\Pana01\Avvio-103A_eeprom-sta_20080712-120542.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Archivos de programa\InfinityBox\Pana01\Avvio-103A_eeprom-sec_20080712-120545.B1E.bin reading [eeprom-complete]... file saved: C:\Archivos de programa\InfinityBox\Pana01\Avvio-103A_eeprom-complete_20080712-120551.B1E.bin reading additional data... done backup critical area Done Check memory... current status: #2, already unlocked already done (mode-0), operation aborted Check memory Failed Finished, Remove/Install battery now ! Time used: 34 sec he also sent the full flash and eeprom read with infinity http://rapidshare.com/files/12820505...O_103.rar.html I hope that these data support to solve this problem with thanks avvio greetings |
07-14-2008, 17:30 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @denisirias It looks like it was some problems with flash files. Files was re-uploaded today, please, download new files and try to flash phone again. |
07-14-2008, 21:48 | #9 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: DAVIE FLORIDA
Member: 309299 Status: Offline Thanks Meter: 259 | Quote:
i will send phone to you tomorrow morning that way you can do some test there | |
07-15-2008, 17:50 | #10 (permalink) |
Member: 252848 Status: Offline Thanks Meter: 2 | Hello again my friends Here is the log for lates attempt to flash...The phone powers on and off now..after flash. i use both generic bin from main server. ==== log opened: [7/15/2008 12:40:08 PM] ==== Application: C:\Program Files\InfinityBox\Pana01\Pana01.exe Loading data, wait... [Infinity Box] v1.50 S/N: 0C0E:***X Wait... Current model: Avvio-103A Ready COM5 ready Loading file v.02... Avvio-103A_G1.0_C00.76_P192_I7880F_0714B01_V11CNx_Nov-30-2007_Generic.B1M.bin loaded COM5 [Serial2] selected Device: Avvio-103A Checking data, wait... Action: flash write Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 0001:22C4 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... backup critical area Done Check memory... Check memory Done Write... reset... done Erasing: Firmware Writing: Firmware repair write error [004FE000]... Ok repair write error [004FE000]... Ok Write Done Finished, Remove/Install battery now ! Time used: 76 sec Loading file v.02... Avvio-103A_G1.0_C00.76_P192_I7880F_0714B01_V11CNx_Nov-30-2007_Generic_ver2.B1M.bin loaded COM5 [Serial2] selected Device: Avvio-103A Checking data, wait... Action: flash write Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 0001:22C4 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... backup critical area Done Check memory... Check memory Done Write... reset... done Erasing: Firmware Writing: Firmware repair write error [004FE000]... Ok repair write error [004FE000]... Ok repair write error [004FF000]... Ok repair write error [004FF000]... Ok Erasing: Firmware error: set erase range error: erase failed: 007FC000 Write Failed Finished, Remove/Install battery now ! Time used: 87 sec |
01-27-2009, 19:23 | #15 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, As I can see it was no any problems during already long time. Just download latest Pana01 update from Infinity-Box support area and try to unlock phone. |
j132 ips unlock done another ps unable to unlock | unlock & flash | Infinity-Box | 21 | 05-03-2009 21:57 |
Avvio 103a Imposible To Unlock | denisirias | Infinity-Box | 32 | 07-05-2008 15:31 |
to Lead - 8138 v106+ (R) unable to unlock ? | Svetli | Cruiser Suite | 5 | 04-08-2005 16:53 |
unable to unlock t28 | jokkergsm | Old Ericsson Phones & Sony Phones | 0 | 06-27-2002 17:22 |
I was unable to unlock Z5 with version 6.7.1/1SAT | sat | Sony | 2 | 01-18-2002 16:47 |
