Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #4 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2001 Location: Morocco Agadir
Member: 3936 Status: Offline Thanks: 57
| Hi me too i have same problem all MT6205 based phones can't go into test mode for read code or format fs in safe mode standard mode working but phone still unlocked this problem is experienced also on philips s200 regards |
| | #5 (permalink) |
| | #6 (permalink) |
| sorry for multipostage here's log from avvio G200 can't go into test mode do not tell me to hold power for long time cause i did it COM3 [VCP0] selected Action: read codes unlock method: read codes Model: Avvio-G200 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6205:8B00]... CPU: MT6205 Connecting, wait... error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 158 sec Remove/Install battery now ! |
| | #7 (permalink) |
| here log for standard unlock mode COM3 [VCP0] selected Device: Avvio-G200 Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: unlock Warning ! After unlock process finished make this: 1. be sure that there is NO any SIM card in phone 2. press phone "Power" button and power-On phone 3. press phone "Power" button and power-Off phone 4. NOTE ! SIM card can be blocked during first power-On so use SIM card that you ready to move to trash w/o problems ! 5. now you can power-On phone with SIM card Do you understand instruction and want to continue ? unlock method: standard Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... . detection phase #2... ................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom]... file saved: C:\Program Files\InfinityBox\MModule\eeprom_20080614-114554.B0E.bin flash: EC22A000000000:18E59F00000000 Backup required data Done Patch required data... detection procedure, wait... detection procedure completed Patch required data Done Special operation... detecting additional parameters... ................ error: additional parameters detection failed Special operation Done Write... flash: EC22A000000000:18E59F00000000 Write: eeprom Write Done Finalization... Finalization Done Finished, time used: 86 sec Remove/Install battery now ! @infinity team please be more clear about pop up window especially step 4 Last edited by GSM Deals; 06-14-2008 at 11:56. |
| | #8 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2005 Location: infinity-box
Member: 130995 Status: Offline Thanks: 9,049
| @GSM Deals Please, follow the instruction that was given to you by software before unlock process !!! You must follow instruction exactly step-by-step !!! |
| | #9 (permalink) | |
| Quote:
and still you didn't answer my question why these phones could not go to test mode there's some bug with software wich should be solved 4. NOTE ! SIM card can be blocked during first power-On so use SIM card that you ready to move to trash w/o problems regards Last edited by GSM Deals; 06-14-2008 at 16:31. | |
| | #10 (permalink) |
| Dear Friend, There is no bugs with software. We have made dfifferent unlock methods for each phone and you must use special method for each phone !!! Regarding instruction: As I can see it's quite clear. If you can not understand this instruction, please, explain what is not clear and we will try to explain you again in other words. |
| | #11 (permalink) |
| so please be more specific and tell me wich method to use with G200 1-i used "read code"&"smart fast" method result software says phone failed to go into test mode 2-i used "standard"&"standard fast" method and try to follow instructions but the phone is still locked please try to be more technical in your answer and explain this in other words "that you ready to move to trash w/o problems" regards |
| | #12 (permalink) |
| Ok... Here is detailed explanation: 4. NOTE ! 4.1. SIM card can be blocked during first power-On: this means, that when you insert sim-card into phone after unlock and when you power-on your lovely phone there is a chance that your lovely sim-card will be blocked forever and you will be unable to use your lovely sim-card any more 4.2. so use SIM card that you ready to move to trash w/o problems: this means, that if you have your lovely working sim-card from your own phonme DO NOT use this sim card, but use sim card that you do not use ordinary but you will be ready to say to this card "bye-bye" just after phone unlock process as I can see you did not understand instruction well and probably you did not foloow it, so please, try to read instruction again, make unlock according to instruction and let's talk about "wark" or "not wark" after you will make unlock process in "standard" mode according to instruction. |
| | #13 (permalink) |
| other thing please try unlock Huawei T201 using version pana01 v1.48 you will get log bellow while old versions like pana01v1.42 works perfect COM3 [VCP0] selected Device: Huawei-T201 Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... error: can't run main loader: Release Power button now Boot Failed Finished, Remove/Install battery now ! Time used: 7 sec |
| | #14 (permalink) |
| @GSM Deals As I remember it was problems with some types of T128. Are you sure that it's problem with software but not with different T128 PCB types ? |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Avvio G200 Keeps on Thrashing SIMS | gesundheit | Infinity-Box | 3 | 01-14-2009 19:00 |
| 29 Mar 2008: SkyZen-EZ200, Avvio-G200, Dirland-X410, Fly-Hi-SLDR supported | InfinitySupport | Infinity-Box | 19 | 08-27-2008 12:12 |
| G200 PANTECH service manual here .. | Boss | Various | 0 | 10-01-2004 20:07 |
