Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) | |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2002
Member: 17851 Status: Offline Thanks: 28
| UNlocked done by standard method. Followed Instructions and warning. First sim on first Power-UP gets it's PIN changed automatically once phone is powered, and unable to determine what PIN Code Phone has entered (automatically). Then another SIM is inserted, upon power-up PIN is changed again by the phone automatically and activated PIN code. Tried to insert 2nd SIM to other phone and phone asks for PIN, SIM was not activated beforehand for PIN security so tried to enter default 1234 PIN---unfortunately it doesn't work. Tried inserting another SIM to AVVIO G200, again SIM PIN Changed is displayed on screen----and sure enough, asks for PIN Code when 3rd SIM inserted to other phone. And it goes on and on and on.... My question: 1. What is the default SIM Pin that the phone change to? 2. Is there an "escape" to this? 3. Is it dangerous and useless to unlock phone unless SIM will be used to the same phone "for eternity"? 4. What have I done wrong? Was the warning an outright call not to unlock the phone and USE other SIM rather thrashing the SIM when inserted to other phones due to SIM Pin code entry unknown? 5. I think the warnings from the soft doesn't says what it really happens to the next SIMs inserted (Just like what happened to the first one) The only known "cure" for this is using a SIM with known PUK in case Pin is blocked. Then let pin be blocked and as phone asks for PUK, enter PUK then you will be able to change PIN code manually even not knowing the PIN Code this F U @#$ Avvio entered Other than that, maybe INFINITY Support Knows.... Quote:
| | #2 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2005 Location: infinity-box
Member: 130995 Status: Offline Thanks: 9,039
| Hello, Are you sure that you followed instruction exactly ? Code: Warning ! After unlock process finished make this: 1. be sure that there is NO any SIM card in phone 2. press phone "Power" button and power-On phone 3. press phone "Power" button and power-Off phone 4. NOTE ! SIM card can be blocked during first power-On so use SIM card that you ready to move to trash w/o problems ! 5. now you can power-On phone with SIM card |
| | #3 (permalink) |
| 100% sure I followed it. my point is this: even you insert another SIM AFTER the procedure you mentioned, the phone automatically ENABLE the SIM PIN and also changing it to some value I don't know....the phone with that SIM works flawlessly....BUT once you insert that SIM that came from the fone to another different FONE-----It asks for SIM PIN (because avvio automatically enabled it).... How would you know now the PIN? To be able to reuse the SIM you have to intentionally enter any no. till the SIM is PUKked, then if you know the PUK you will be able to reset SIM PIN. Or put it back to the AVVIO and use it there, AVVIO won't ask you the SIM PIN--- |
| | #4 (permalink) |
| Please, check instruction once again. You must follow it exactly, all steps from 1. to 5. (even if you think that some steps is stupid). After step-5 you can use phone with any sim card. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| avvio g200 | yalamandareddy | Infinity-Box | 14 | 01-17-2009 07:32 |
| 29 Mar 2008: SkyZen-EZ200, Avvio-G200, Dirland-X410, Fly-Hi-SLDR supported | InfinitySupport | Infinity-Box | 19 | 08-27-2008 12:12 |
| Samsung R220 keeps on restarting with Hutch(Orange) sim | omkar_ghaisas | VLSI, Conexant, Skyworks and Old Models | 1 | 05-26-2004 06:22 |
