-   Infinity-Box (http://forum.gsmhosting.com/vbb/f296/)
-   -   b159 not unlock (http://forum.gsmhosting.com/vbb/f296/b159-not-unlock-1204834/)
rajivmobil 02-10-2011 10:35
b159 not unlock
dear sir pls help me
HARDWARE : SCNNZ317
COMPILE : May 28 2010 (17:51:49)
REALEASE : Mar 29 2007 (20:00:00)
SW Version : QSC6010 SCNNZ 3170
is not unlock
<<<MEGATRON>>> 02-10-2011 11:19
HARDWARE : SCNNZ317
is not unlock
Hello,
Please Use 1.41 Module Only For Samsung This Will B Fixed In Upcoming Updates
Wbr
<<<Megatron>>>
rajivmobil 02-10-2011 11:43
i Use 1.41 and 1.43 Module Only For Samsung but not unlock
<<<MEGATRON>>> 02-10-2011 11:58
Hello,
Please Post Logs As Without Logs Can't Help
Wbr
<<<Megatron>>>
rajivmobil 02-10-2011 12:04
COM10 [sacumdm0] selected
module v1.41
Device: Samsung-SCH-B159
operation: UART unlock
Phone should be Switched ON !
connecting...
Connecting, wait...
error: can't activate test mode
If phone can not be connected after several tries make this:
1. Insert original sim card in phone
2. Power-On phone
3. go to Menu, press 6 then * and type password 123456
4. go to "Port Map", HKF
5. select "UART1"
error: operation failed
Finished, time used: 15 sec
<<<MEGATRON>>> 02-10-2011 12:08
module v1.41
connecting...
Connecting, wait...
2. Power-On phone
5. select "UART1"
Hello,
You Are Using USB Cable Use UART RJ45 Cable For UART Unlock
Wbr
<<<Megatron>>>
rajivmobil 02-11-2011 05:46
thans sir it will done unlock
tshooter 02-11-2011 07:19
COM2 [VCP0] selected
module v1.41
Device: Samsung-SCH-B209, B309, B319, B619, B339FM
operation: SP-unlock
connecting...
Connecting, wait...
2. Power-On phone
5. select "UART1"
Finished, time used: 26 sec
tshooter 02-11-2011 07:20
User need to put this code 47*869#123580 , a menu will appear on the phone screen
select the option "portmap" then select hfk after select hfk , select uart1 and save it .
Restart phone and try spunlock again from Step 2 already do this
tshooter 02-11-2011 08:31
allredy 1st use usb done ffhone restart after code 47*869#123580 , a menu will appear on the phone screen
Restart phone and try spunlock again from Step 2 already do this after phone display shwo ENTER COMMAND INPUT VELUE INDEX*01 COM2 [VCP0] selected
module v1.41
connecting...
Connecting, wait...
2. Power-On phone
5. select "UART1"
Page generated in 0.23380 seconds with 5 queries
