07-17-2011, 08:01 | #1 (permalink) |
No Life Poster Join Date: Dec 2009
Member: 1194176 Status: Offline Thanks Meter: 203 | b159 unlock not done SAMSUNG B159 DE-26 selected.. samsung b159 de-26... downloading mode... Wait reconnecting port... Patching in progress... patching done... Wait reconnecting for restart... Done... Phones should be restart now... Finished, time used: 2 min 2 sec but here set not restar and also set on download mode showthis error qsc boot download address 0+01f4000 0+01f4fff write main : de28 boot : dc24 please solve this one |
07-19-2011, 05:22 | #4 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: Just Imagine Age: 42
Member: 1191481 Status: Offline Sonork: 1592603 Thanks Meter: 1,373 | Quote:
After Usb Unlock Did You Perform Second Step Uart Unlock? If You Face Any Problem Contact Me On Yahoo Wbr <<<Megatron>>> | |
07-19-2011, 07:08 | #5 (permalink) |
No Life Poster Join Date: Sep 2008 Location: in your hart Age: 40
Member: 864102 Status: Offline Sonork: 100.1617637 Thanks Meter: 146 | what is handset colour its red or blue? if than do normal unlocking if colour is blue than add me on yahoo i will help you [email protected] |
07-19-2011, 07:08 | #6 (permalink) |
Member: 864102 Status: Offline Sonork: 100.1617637 Thanks Meter: 146 | what is handset colour its red or blue? if colour is red than do normal unlocking if colour is blue than add me on yahoo i will help you [email protected] |
07-20-2011, 10:32 | #7 (permalink) |
Member: 1194176 Status: Offline Thanks Meter: 203 | BLUE COLOUR HANDSET SIR IC COMBO SOLOUTION HERE BUT INFINIT WAS NOT THIS TIME ravitelecom no need to panic. your model is new or old type of B159 ? put phone in emergency mode connect usb to pc open MULTI CDMA TOOL select model SCH-B159 select modem usb port go to samsung tab tick on BOOT or BOOT MODE press unlock it will ask you to ENTER CHOICE if you phone is OLD MODEL OLD COLOR HANDSET then type "TYPE 1" Without comma if you phone is NEW MODEL NEW COLOR HANDSET then type "TYPE 2" Without comma now wait and once process finish remove cable and battery and test phone with card... b159 unlocking problem in new version solve sir - Cdma Gsm Forum Mygsmindia. |
07-20-2011, 10:46 | #8 (permalink) | |
Product Supporter Join Date: Jun 2010
Member: 1319166 Status: Offline Thanks Meter: 1,476 | Next update we will try to find this pcb and support it . Quote:
Till now i have not received samples i will try to find one sample and support asap . Wbr | |
07-20-2011, 11:14 | #9 (permalink) | |
Or If You Need Fast Update Then You Can Make New Version Dump Read And Send Link In Private Msg Wbr <<<Megatron>>> | |
08-17-2011, 08:37 | #10 (permalink) |
Freak Poster Join Date: Sep 2006 Location: ludhiana(punjab)
Member: 355291 Status: Offline Thanks Meter: 20 | COM4 [sacumdm0] selected module v1.61 Device: Samsung-SCH-B159 operation: DE-28 (blue) boot unlock (Force mode) Phone should be Switched ON ! connecting... dm mode... downloading mode failed... Finished, time used: 5 sec |
08-17-2011, 08:39 | #11 (permalink) |
Member: 355291 Status: Offline Thanks Meter: 20 | HARDWARE : SCNNZ317 COMPILE : May 28 2010 (17:51:49) REALEASE : Mar 29 2007 (20:00:00) SW Version : QSC6010 SCNNZ 3170 --------------------------------------------------------- Phonce code : 0000 Finished, time used: 3 sec |
08-17-2011, 09:06 | #12 (permalink) | |
As You Are Using Force Mode Phone Should B IN Download Mode 9+Pwr And Then Perform Unlock Operation Wbr <<<Megatron>>> | |
08-17-2011, 14:26 | #13 (permalink) | |
Member: 1319166 Status: Offline Thanks Meter: 1,476 | Use USB-Cabel E-210 Quote:
Kindly Use USB-CABEL Samsung ('E210') .I think you are using Rj-45 Cabel . Regards | |
u8220 pulse driver for unlock | doller | VygisToolbox | 2 | 11-12-2011 18:44 |
U fone g3610 unlock done | biochemistali | Dragon Box | 1 | 07-16-2011 10:29 |
micromax Q5 imei not found (Solved) | global_mobile | AVATOR BOX | 5 | 07-16-2011 06:01 |
