Old 05-04-2009, 12:02   #1 (permalink)
rajesh_ch's Avatar
Member: 618404
Thanks Meter: 311
b259 samsung cdma sucessfully unlocked
COM5 [VCP0] selected
module v1.03
Device: Samsung-SCH-B259
Checking data, wait...
Action: unlock
Phone should be Switched ON !
Connecting, wait...
Phone detected, wait...
step-1 done
step-2 done
step-3 done
operation finished
Finished, time used: 13 sec
Remove/Install battery now !
thxs.infinity team......................................
wbr.
rajesh ch.
The Following 2 Users Say Thank You to rajesh_ch For This Useful Post:
Old 05-05-2009, 21:19   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
module v1.03
Action: unlock
Connecting, wait...
step-1 done
step-2 done
step-3 done
operation finished
wbr.
rajesh ch.
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type)
and what is possible problems (so we will be able to fix it) and successfully done work.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 09-03-2015, 07:26   #3 (permalink)
Member: 1726688
Thanks Meter: 9
b259 samsung cdma
pls solution this problem
COM63 [sscdmdm0] selected
module v2.05
Device: Samsung-SCH-B239, B259, B279, F302
operation: SP-unlock
connecting...
Connecting, wait...
error: can't activate test mode
If phone can not be connected after several tries make this:
1. Insert original sim card in phone
2. Power-On phone
3. go to Menu, press 6 then * and type password 123456
4. go to "Port Map", HKF
5. select "UART1"
If problem still exist make this:
2. Power-On phone
3. go to Menu, press 47*869#123580
5. select "UART2"
error: operation failed
Finished, time used: 25 sec
Old 09-03-2015, 07:39   #4 (permalink)
avtarkaint's Avatar
Member: 452162
Sonork: 100.1592470
Thanks Meter: 440
post in infinity CDMA section.
The Following User Says Thank You to avtarkaint For This Useful Post:
Old 09-03-2015, 08:01   #5 (permalink)
Member: 459784
Sonork: +91-9179403087
Thanks Meter: 1,543
Originally Posted by munajir85 View Post
b259 samsung cdma
module v2.05
connecting...
Connecting, wait...
2. Power-On phone
5. select "UART1"
2. Power-On phone
5. select "UART2"
Hello, Dont Use Usb Cable - for unlock this model you need uart cable - rj45
Open Back Sticker You Will Be See Some Pinout Just Make Jumper And Unlock By Normal Any Rx Tx Cable
Here Is Cable Pinout
The Following User Says Thank You to pradeep_kus For This Useful Post:
Old 09-03-2015, 17:21   #6 (permalink)
Member: 1726688
Thanks Meter: 9
Thank you
pradip kus Rj-45 cable kat kar Rx-Tx Vcc Gnd Connect kiya 10 Second me hogaya.
COM41 [VCP0] selected
Samsung B259 succsess unlock-
Green mobile raver 9881365569
module v2.05
connecting...
Connecting, wait...
step-1 done
step-2 done
step-3 done
operation finished
Finished, time used: 37 sec
The Following User Says Thank You to munajir85 For This Useful Post:
Old 09-04-2015, 06:05   #7 (permalink)
Member: 1726688
Thanks Meter: 9
plese infinity support Sir...
Samsung B539 ki flash file chahiye urjent.blinking problem hai.
Not available in infinity support.
thankyou infinity support
B259 samsung cdma unlock successfully!! kmaxmax Infinity-Box 3 05-05-2009 15:45
Samsung A707SCII Sucessfully Unlocked Ultimate Server NSPRO 0 02-25-2009 15:43
Samsung A127 Sucessfully unlocked .::AZEEM::. UST Pro II 2 01-22-2009 12:56
Samsung x530 sucessfully unlock zhettie_foxie Samsung Flashers, Software, Firmware. 1 07-16-2007 14:03
Page generated in 0.20982 seconds with 9 queries
