05-03-2017, 08:54 | #1 (permalink) |
Freak Poster Join Date: Aug 2014 Location: kolkata
Member: 2234421 Status: Offline Sonork: 100.1674816 Thanks Meter: 60 | b310e format done Chinese Miracle II [SPD module] v 1.25 Operation : Check/Read Info [ v1.25 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 44 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6530 , FDLStat : 00C0 [0] Flash DIE : 00C8 0060 0017 0000 [0] Flash VEN : GigaDevice , GD25LQ64 [0] Flash CAP : 00800000 Elapsed: 00:00:16 Reconnect Power/Cable! Operation : Read FullFlash [ v1.25 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 44 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6530 , FDLStat : 00C0 [0] Flash DIE : 00C8 0060 0017 0000 [0] Flash VEN : GigaDevice , GD25LQ64 [0] Flash CAP : 00800000 Read Flash Content Read Ok , collect info Platform : MOCOR_W13.09_FP_R5.0.2_Debug sc6500_samsung_PitonDS_SWA ExtInfo : LevelofLock 00000000 00000000 Project : SC6500_SAMSUNG HWInfo : SC6500_EiderVEDS Compile : 11-09-2015 15:40:13 Set FileInfo : Model Vendor : b310e Model Name : b310e ExtInfo Data : eng Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6530_SPD6500_008 00000_MOCOR_W13.09_FP_R5.0.2_Debug_sc6500_samsung_ PitonDS_SWA_11092015154013_eng__b310e-b310e.bin Done! Elapsed: 00:01:26 Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.25 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 44 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6530 , FDLStat : 00C0 [0] Flash DIE : 00C8 0060 0017 0000 [0] Flash VEN : GigaDevice , GD25LQ64 [0] Flash CAP : 00800000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:37 Reconnect Power/Cable! |
