Old 02-11-2009, 09:46   #1 (permalink)
.::adnangsm::.'s Avatar
Member: 802214
Sonork: 100.1573572
Thanks Meter: 95
Zong-A136 unlock 100%
==== log: [2/11/2009 1:40:11 PM] ====
COM9 [VCP0] selected
module v1.61
Device: Zong-A136
Checking data, wait...
Action: unlock
unlock method-1
Boot ...
loader: standard
type: 4
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 00EC:257E
Connecting Done
Check hardware ...
sw version: PAK-P108A2V1.0.0B01 CMPAK-P108A2B07-En-PK01 g3dBV2.0 Apr 24 2008
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20090211-134025.B1E.bin
loading data...
wrong database file: C:\Program Files\InfinityBox\Pana01\z225_eep65535.cfg
error: can't load database v.11
reading eeprom-security...
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20090211-134026.B1E.bin
reading eeprom-complete...
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20090211-134027.B1E.bin
reading additional data...
file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20090211-134030.B1E.bin
backup critical area Done
Check memory ...
lock found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 21 sec
Remove/Install battery now !
The Following User Says Thank You to .::adnangsm::. For This Useful Post:
Old 02-12-2009, 02:16   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
module v1.61
Device: Zong-A136
Action: unlock
unlock method-1
Boot ...
loader: standard
type: 4
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 00EC:257E
Connecting Done
Check hardware ...
Check hardware Done
loading data...
Check memory ...
lock found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type)
and what is possible problems (so we will be able to fix it) and successfully done work.
Old 02-12-2009, 05:44   #3 (permalink)
Member: 199814
Thanks Meter: 1,960
but its kind a old story tested so many months ago..
Old 02-12-2009, 20:49   #4 (permalink)
Member: 130995
Hello,
Each test report contain flash chip type, firmware version etc., it's unique information for each phone so each test report is quite important.
Zong a136 unlock exe thewarismobiles FuriousGold 0 03-27-2010 13:30
02 Nov 2008: LG-KP135, SFR-111, Bird-V5518+, ZTE-A136, Zong-A136 models supported InfinitySupport Infinity-Box 36 06-21-2009 10:59
''""::another zong a136 unlock thanks u infinty team''"":: ehsas_ghum Infinity-Box 0 04-23-2009 09:47
Zong-A136 unlock murtaza_nns Infinity-Box 16 02-21-2009 17:42
ZTE-A136,Zong-A136 unlock MALIKtelecom Infinity-Box 1 12-18-2008 19:15
Page generated in 0.17297 seconds with 10 queries
