01-22-2017, 07:54 | #1 (permalink) |
No Life Poster Join Date: Nov 2015 Age: 25
Member: 2493574 Status: Offline Thanks Meter: 605 | bad file detect backup by cm2:https://drive.google.com/file/d/0Bws...ew?usp=sharing need help by cm2 team otherwise backup meaning not safe by cm2 later firmware would not be use any more Last edited by Shikhar12; 01-22-2017 at 07:56. Reason: spelling |
01-22-2017, 09:59 | #5 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Quote:
Its 6260 write factory not supported use FlashTool_v5.1440.00 | |
The Following User Says Thank You to princesaddam For This Useful Post: |
01-22-2017, 10:14 | #6 (permalink) |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,275 | |
The Following User Says Thank You to malka4u For This Useful Post: |
01-23-2017, 06:25 | #11 (permalink) |
No Life Poster Join Date: May 2016 Location: Madina, Accra, GHANA
Member: 2575234 Status: Offline Thanks Meter: 1,134 | Hello, instead of backing up factory firmware from this smaller CPUs, make full firmware backup instead. You will always have this problem(bad file) when you make factory firmware backup. Just don't click the factory firmware options during backup. Titbit Last edited by Kwesi_Roy_GH; 01-23-2017 at 06:34. |
The Following User Says Thank You to Kwesi_Roy_GH For This Useful Post: |
