Old 11-07-2014, 00:35   #1 (permalink)
turca's Avatar
Member: 211017
Thanks Meter: 262
Bad file detected
I read backup phone working.
I need repair other phone, but "BAD FILE DETECTED"
I test other file read by Cm2mtk 1.05 same problem. Solve this bug
Operation : Check / Read Info [ v1.05 ]
Wait for phone...
Phone found! [ 97 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6571
BB_CPU_HW : CA00
BB_CPU_SW : 8D00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6571_S00
Processing BROM stage
BLVersion : 0xFE
SecCfgVal : 0x00000000
BromVersion : 0x05
BLVersion : 0xFE
Preloader Status : Not active (Erased)
Processing DA stage
DA Select done , sending
NAND_ID : 002C00BC009000660054000000000000
eMMC_ID : 00000000000000000000000000000000
DA Stat : v4.2 on BBID : 0x8B
Configure emi settings
DA Sent. Configure setting now ...
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x007A , [Micron] NAND_MT29C4G48MAAHBAAKS
[NAND] : FLASH_DIE : 002C 00BC 0090 0066 0054 0000 0000
[NAND] : FLASH_LEN : 0x20000000
INT RAM : 0x00020000
EXT RAM : 0x10000000
BOOT TYPE : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Initial info read Ok!
Done!
Elapsed: 00:00:11
Reconnect Power/Cable!
Operation : Read Flash [ v1.05 ]
Wait for phone...
Phone found! [ 97 ]
Sync...
Boot Info :
BB_CPU_ID : 6571
BB_CPU_HW : CA00
BB_CPU_SW : 8D00
BB_CPU_SB : 0000
BLVersion : 0xFE
BromVersion : 0x05
BLVersion : 0xFE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Reading Flash Conent now ...
USBDL : Init HSUSB Ok!
NAND settings not exists, will check now ...
Settings read Ok!
- > Re-connect battery and start operation again!
Done!
Elapsed: 00:00:50
Wait for phone...
Phone found! [ 97 ]
Sync...
Boot Info :
BB_CPU_ID : 6571
BB_CPU_HW : CA00
BB_CPU_SW : 8D00
BB_CPU_SB : 0000
BLVersion : 0xFE
BromVersion : 0x05
BLVersion : 0xFE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
USBDL : Skip HSUSB init
Read Ok , collect info
MTKxCPU : MT6571
MTKxPRJ : blu
Saved to : C:\Documents and Settings\TURCA\Desktop\MT6571__blu.ispff
Done!
Elapsed: 00:17:36
Load File
Bad file detected!
Old 11-07-2014, 04:22   #2 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,181
Hello, because NAND writing not activated yet.
Supported Read Info, Read Flash and Format FS.
The Following User Says Thank You to Dzirt For This Useful Post:
Old 11-07-2014, 04:22   #3 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,181
Old 11-08-2014, 06:08   #4 (permalink)
FullFlashPak's Avatar
Member: 782530
Thanks Meter: 8,125
Boss when supported nand writing flash active ????
Page generated in 0.23480 seconds with 7 queries
