07-01-2016, 18:07 | #1 (permalink) |
Major Poster Join Date: Jul 2013 Location: 127.0.0.1
Member: 1970941 Status: Offline Thanks Meter: 4 | Bad file detected ! This is full info for this phone Code: Operation : Check / Read Info [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 82 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : 002C00BC009000550056000000000000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0091 , [Micron] NAND_MT29C4G48MAAHBAAKS_5WT [NAND] : FLASH_DIE : 002C 00BC 0090 0055 0056 0000 0000 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/01/NIM_Px-2 DEV RID : 0x16F9CADB1E0F9E773C43893EF7A60BE6 INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : samsung ProdName : SM-G530F ProdModel : SM-G530F Device : SM-G530F AndroidVer: 4.4.4 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1 Done! Elapsed: 00:00:20 Thank you. Last edited by haloup; 07-01-2016 at 18:16. |
07-01-2016, 18:34 | #2 (permalink) | |
No Life Poster Join Date: Oct 2015 Location: Unknown
Member: 2469611 Status: Offline Thanks Meter: 389 | Quote:
WBR | |
The Following User Says Thank You to CYB3R GSM For This Useful Post: |
07-01-2016, 21:24 | #4 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
CM2 will support generic structure phone in near 2-3 updates for writing. But not sure, when exactly it will be finished. Next time make FW backup, instead of dumps. You can send me that ispff, will check it and try make something. | |
07-02-2016, 00:28 | #5 (permalink) | |
Member: 1970941 Status: Offline Thanks Meter: 4 | Quote:
https://userscloud.com/vp2hkgnpudby | |
