12-31-2012, 14:29 | #1 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Nigeria Lagos
Member: 1014618 Status: Offline Sonork: 100.1637137 Thanks Meter: 110 | Bad sl3 code given card found: S/N 2A51:0118 registered to: TIMBERRY Connect phone on selected interface... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Unlock procedure started... Using F-bus count... Sending code 166086557289413 Level : 7 to SimLock Server... Simlock Server Answer: Bad Code... Done! |
12-31-2012, 17:40 | #2 (permalink) |
Member: 1014618 Status: Offline Sonork: 100.1637137 Thanks Meter: 110 | i ve reset counter same problem Checkings and reset counters... Counters : Key 0 [3] , Fbus 10 [10] Backup data... Backup created... Checking... Counters : Key 0 [3] , Fbus 0 [10] Reset Done! All done Checkings and reset counters... Counters : Key 0 [3] , Fbus 0 [10] No need reset, counters are Ok All done Using F-bus count... Sending code 166086557289413 Level : 7 to SimLock Server... Simlock Server Answer: Bad Code... Done! |
12-31-2012, 17:40 | #3 (permalink) |
01-02-2013, 19:38 | #7 (permalink) |
Member: 1014618 Status: Offline Sonork: 100.1637137 Thanks Meter: 110 | tried but says code error i ve tier again same error i even change to +7,+6..................+1 still error Last edited by TBOUY; 01-02-2013 at 19:44. |
01-02-2013, 22:21 | #8 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Could you, please, select only one thread for this problem discussion, I can not understand where we should answer you. What should be final thread ? |
