08-25-2008, 09:08 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: NEAR YOU
Member: 205427 Status: Offline Sonork: 100.1580937 Thanks Meter: 1,162 | >>> Bad Software Repair 100% Success <<< Thanks to the great team for their support >>>> COM3 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: repair "bad software" Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:0403:000C boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: MOBILEDEN25_06B_PCB01_GPRS_MT6225_S00.M608_V_1_20_ P1HXM25BC30_INTEL_CN.BIN ver. sw2: M608_V_1.20_P1HxM25BC30_INTEL_CN, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting firmware protection... detecting firmware structure #8... ...................... done detecting firmware structure #9... detecting area #1... .......................................... area #1 is Ok done detecting firmware protection done Finished, time used: 31 sec Remove/Install battery now ! ==== log: [25-08-2008 13:32:56] ==== COM3 [VCP0] selected Action: repair "bad software" Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:0403:000C Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: M608_V_1.20_P1HxM25BC30_INTEL_CN Version: Mobileden25_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #6 (mode-1)... done 163 byte(s) read writing data... verification... verification Ok Finished, time used: 11 sec Remove/Install battery now ! |
5310 bad software repair 100% ok | guljee786 | Infinity-Box | 0 | 04-05-2009 16:22 |
>>> V3re OC.F4 unlock successfully <<< | keaelite | Smart-Clip | 7 | 06-24-2008 08:42 |
>>> 3units of C450 unlocked successfully <<< | keaelite | UST Pro II | 1 | 05-07-2008 07:09 |
>>> L6 Unlock Problem - 100% Solution <<< | RNC_EBM | Ultima Box Light | 13 | 03-25-2007 15:43 |
>>> K750 to W800 - 100% WORKING <<< | RNC_EBM | HWK | 88 | 05-13-2006 16:49 |
