12-22-2005, 17:33 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Did you read instruction carefully and made all step-by-step ? Try to repeat unlock process and make EXACTLY by instruction that you will see in software log window. If this not helps then send me Log file, read flash from phone and send to me too: [email protected] |
12-22-2005, 18:25 | #4 (permalink) |
Freak Poster Join Date: Dec 2005 Location: in unlocker world Age: 44
Member: 207809 Status: Offline Thanks Meter: 13 | Phone must be in TEST-MODE: * + # + Power Connecting, wait... Phone found, wait... Connection Ok Unlocking... Imei: 356404000645832 SEC ver: 00.11Sg(0002) SW ver: NBG_LEOPARD_05.19.01SMARTI_SDB1SGOLDliteV1 MMI ver: Mmi:VS3-VA47,Jul22200504:03:08 In progress[EEP01_356404000645832]... In progress[EEP02_356404000645832]... Found: Network Err: unlock not possible[01] Done Finished but phone stil locked |
12-22-2005, 18:39 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | I think there are some difference between "not unlocked" and "telephon now is locked no accept any card provider now". Please, read flash from this phone and send to: [email protected] We will check it ASAP and inform you about results. |
12-22-2005, 19:53 | #6 (permalink) |
No Life Poster Join Date: Mar 2001 Location: ALBANIA(Tirana) Age: 51
Member: 3617 Status: Offline Thanks Meter: 578 | i READ FLASH FOR x 400 Version 48M YESTERDAY and all operation is finished but the soft dont said me where to SAVE and now somewhere is in computer but i dont know how can i find it |
12-22-2005, 21:01 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, File with backup located in the same folder where is software located. File name is: "Backup....." As about X400: if you have problems pls send me Log file also. |
12-22-2005, 22:14 | #9 (permalink) | |
12-26-2005, 18:25 | #11 (permalink) | |
No Life Poster Join Date: Jan 2002 Location: tunis,Tunisia Age: 54
Member: 8228 Status: Offline Sonork: 12399830 Thanks Meter: 136 | Quote:
thx | |
12-29-2005, 08:51 | #12 (permalink) | |
Freak Poster Join Date: Sep 2004 Location: india
Member: 83511 Status: Offline Thanks Meter: 34 | You did not understand the problem ..... Quote:
12-30-2005, 02:32 | #13 (permalink) |
Freak Poster Join Date: Aug 2001 Location: on air Age: 46
Member: 5921 Status: Offline Thanks Meter: 5 | @infinity team i have the same problem with one VS3. now the phone is working only to one operator, the rest "invalid sim" i see that the program make a backup of the eprom. does it help in repairing and unlocking the phone? |
12-30-2005, 09:07 | #14 (permalink) | |
What do you mean "the same" problem ? The same as what ? What you want to repair ? Does your phone now damaged (can't beleive) or just sp-locked (in the same condition as before) ? If you have any problems with VS3 unlock with InfinityBox here is the steps to get phone unlocked: 1. Send file Log_Pana01.txt to [email protected] 2. Read flash from your phone 3. Use WinRar, make archive (better split big files to smaller parts) 4. Send backup files to [email protected] also you can post info from software Log window here so we can check it fast. After we will receive Log file and backup file we can check what can be wrong and to give you some advices how to solve your problem. | |
12-30-2005, 13:26 | #15 (permalink) |
Member: 5921 Status: Offline Thanks Meter: 5 | problem solved!!! ) check the file log_pana01.txt you will find there the code. use la last code you find there (8 digit code) and then follow the procedure to enter the code. for me worked 100%!! Great Team, Great Support!! |
Problem on VS3 | UnlockerPT | FuriousGold | 2 | 09-01-2007 14:13 |
any news on VS3 ? | sjakie | SAGEM JTAG UNLOCKER | 3 | 01-10-2006 16:27 |
powering on problems after bad unlock with GX-xx | iowtheme2 | Sharp | 0 | 06-09-2005 19:16 |
need to fix display on mc60 after bad unlock | jab | E-Gold Based Phones | 2 | 04-24-2005 15:46 |
how to repar A3X that don't power on, cause a bad unlock | gsm flying free | x1x to x45/x50 | 0 | 08-14-2001 09:31 |
