10-01-2015, 07:34 | #1 (permalink) |
No Life Poster Join Date: Apr 2013 Location: Uzbekistan / Bukhara
Member: 1912005 Status: Offline Sonork: 100.1658592 Thanks Meter: 622 | Fly DS123 MT6252 Phonebook error Read phonebook logs Code: Operation : Read UserData [ v1.32 ] PhoneBook : Enabled PhoneBook : VCFv3 Format output Enabled 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 7 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 00C3 BB_CPU_HW : 0001 BB_CPU_SW : CA20 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MTxxx BB_CPU_SN : 00000000000000000000000000000000 BROM Protocol Version : FF Setting... Setting done , result code 0x430E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW NOT Found :( Boot Error! Operation Failed Elapsed: 00:00:38 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.32 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 7 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 00C3 BB_CPU_HW : 0001 BB_CPU_SW : CA20 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MTxxx BB_CPU_SN : 00000000000000000000000000000000 BROM Protocol Version : FF Setting... Setting done , result code 0x430E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW NOT Found :( Boot Error! Operation Failed Elapsed: 00:00:01 Reconnect Power/Cable! Code: Operation : Check / Read Info [ v1.32 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 7 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 00C3 BB_CPU_HW : 0001 BB_CPU_SW : CA20 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MTxxx BB_CPU_SN : 00000000000000000000000000000000 BROM Protocol Version : FF Setting... Setting done , result code 0x430E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW NOT Found :( Boot Error! Operation Failed Elapsed: 00:00:03 Reconnect Power/Cable! WBG1509Y_0202_PCB01_GPRS_MT6252_S01.1509Y_0202_V16 48.rar ? RGhost ? ????????????? |
