04-05-2016, 12:13 | #1 (permalink) |
Banned Join Date: Mar 2016
Member: 2548094 Status: Offline Sonork: 100.1582347 Thanks Meter: 20 | Huawei Meetuu (Clone) Problem reading this phone clone Huawei Meetuu. can not read info . Card found : S/N : 3EA4381E , v0130 Chinese Miracle II [MTK module] v 1.44 Operation : Check / Read Info [ v1.44 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... [DA_ERROR] : SECURITY_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! Where is problem. I have unlock its boot loader also. Phone have virus inside. Please need urgent help and flash file. Thanks Br, Raja |
04-06-2016, 18:21 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Unfortunately have no any working solution righ now. If you can hold it for a week - we can try. |
04-10-2016, 09:33 | #5 (permalink) |
Member: 2548094 Status: Offline Sonork: 100.1582347 Thanks Meter: 20 | Hi sir, One more model like SAME but with COPY huawei AnboAB001 FREEMe Os 5.2. Operation : Check / Read Info [ v1.44 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... [DA_ERROR] : SECURITY_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:20 Reconnect Power/Cable! Now have two model with same Fault. I am waiting sir Jaydi. Thanks Br, Raja |
