Old 09-01-2011, 23:20   #1 (permalink)
turca's Avatar
Member: 211017
Thanks Meter: 312
BAK-MP203WF no repair three imei
I have phone with three sim
MODEL IS BAK= BAK-MP203WF
Action: read/check information
Model: _Autodetect MT6228-6268 NAND
Checking data, wait...
Phone should be Switched ON !
Connecting, wait...
Phone detected, wait...
Hardware version: MT6235, E04
Hardware version: PX
Software version: TL_GG950PU823_F28LI0
Software date: 2000.00.00
Barcode: MT012345678901234567
imei-1: 3XXXX0036869463
imei-2: 3XXXX0036961260
imei-3: 3XXXX0036869463
Finished, time used: 15 sec
Remove/Install battery now !
problem is freeze after format phone work but no repair three imei help-me
Old 09-01-2011, 23:34   #2 (permalink)
turca's Avatar
Member: 211017
Thanks Meter: 312
after format:
COM3 [VCP0] selected
module v4.01
Device: _Autodetect MT6228-6268 NAND
Action: reset settings ("format ffs") NAND
interface: BROM_DLL_v3.1016.00
Connect...
Connecting...
Booting...
Release Power button now !
bootcode current/expected: 3.2/3.2
CPU: 6235:8A04:8A01
status: FF
bbchip bl ver: FE
NOR flash chip: not installed
NAND flash id[0053]: 00AD:00A100000015 [HYNIX] H8BCS0PG0MBP
chip size: 128Mb
page/spare size: 0800/0040
pages per block: 0040
bits i/o: 08
address cycles: 04
internal RAM size: 00010000
external RAM: absent
done
Set baudrate (921600)...
done
ram test...
testing 32bit...
32bit ram test passed
testing 16bit...
16bit ram test passed
ram test passed
===> detect existing firmware structure...
detect ffs...
ffs offset/size: 02800000/05800000
firmware size: 40Mb
ffs size: 88Mb
detect sec ro...
detect custom parameters...
detect project-id...
project-id: TL_GG950PU823_F28LI0A_00.98
detect NAND info...
number of areas/bytes to read: 1:001A0000
reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)...
nfi area detection...
bootloader version: TELACOM35_08B_PMWY_BOOTLOADER_V005_MT6235B_TL_GG95 0PU823_F28LI0A
nfi area detection (3 cores) finished: Ok
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
startup code area #1 detection done
rom info ver: 07
sw version: TELACOM35_08B_PMWY_PCB01_GPRS_MT6235B_S01.TL_GG950 PU823_F28LI0A_00_98.BIN
project-id: TL_GG950PU823_F28LI0A_00.98, 00000000
code offset: 00000000
ffs offset/size [01]: 02800000/05800000
rom info structure: [standard] type (07)
TCL-ID is absent
===> done
New firmware found (v.4.01, database date: 19.08.2011):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare – Secure Data Logistics or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
warning: can not format: HW_STORAGE_NOR is not present
Format...
autodetection mode...
Format done
Disconnect...
done
Finished, time used: 1 min 16 sec
Connecting, wait...
imei-1: "
imei-2: "
imei-3: "
Finished, time used: 25 sec
Action: "repair imei"
Connecting, wait...
imei-1: "
imei write method: mode-1
imei write channel: imei #1 for dual sim/mono CPU
new imei-1: 3XXXXX036869463
verification Ok
Finished, time used: 3 sec
Connecting, wait...
imei-2: "
imei write channel: imei #2 for dual sim/mono CPU
new imei-2: 3XXXXX036961260
verification Ok
for three sim:
Use only for mode-3 !
I select mode-3 but information is: method is not supported yet
Old 09-02-2011, 10:06   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
we are working under 3 & 4 IMEI writing problem
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 20:09
Nokia 51xx/61xx imei changer ver. 1.10?????? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 04-06-2012 16:22
6110 imei changer !!!!!! Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 11-21-2011 01:44
no one can unlock 6110 05.40 25-5-99 fondas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 09-22-1999 08:03
Page generated in 0.15140 seconds with 9 queries
