08-28-2009, 10:33 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: ATI atheeq technical(srilanka)
Member: 709520 Status: Offline Thanks Meter: 275 | basics |
08-28-2009, 21:17 | #2 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Islamabad--Pakistan
Member: 194128 Status: Offline Thanks Meter: 303 | 1-Switch must be at FBUS position. 2-Get the cable of desired phone model,as suggested by InfinityShell. 3-Connect the cable in Left RJ45 holder(USB Virtual COM Port) for fastest communication speed, you may use Right RJ45 holder(Real Serial COM Port) too but communication speed will be slow as compared to "Virtul USB COM Port". 4-LEDs are for indicating Rx(Recieve Signal) and Tx(Transmit Signal) communication. 5-Perform your desired operation i.e Flash/Unlock.. Hopefully this guide will help you to understand. Best Regards! yawarniazi Last edited by yawarniazi; 08-28-2009 at 21:23. |
08-29-2009, 05:15 | #5 (permalink) |
Member: 709520 Status: Offline Thanks Meter: 275 | my problem is when i connect the phone tx led not blinking? this is my first phone. also phone is not booting in software. another question sir. what is chineese miracle software and why need pin finder |
08-29-2009, 08:24 | #6 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Quote:
Please, read this: 1. http://forum.gsmhosting.com/vbb/showthread.php?t=342807 2. C:\Program Files\InfinityBox\Documentation | |
08-31-2009, 05:32 | #8 (permalink) |
No Life Poster Join Date: Oct 2007 Location: MX-Key and me ...The Best
Member: 617692 Status: Offline Thanks Meter: 306 | Brother let see 1. Update your Pinfinder with your infinity Box (If updated then skip this step) 2. Find the correct cable of pinfinder for your phone 3. Connect your pinfinder with your infinity box. 4. Open PinFinder software 5. After opening select correct Com Port or check Autor selection sign in advance settings and then press Detect Adapter Button. 6. Select Cable Type that you have chosen for you mobile (see label on the cable). 7. Connect your mobile with that cable and also attatch pins of 3.0 volte.(see that you have connected correct pins negitive and positive. Do not use battery) 8. Alse select your correct flash chip base. For example we use mt6225 etc for chinea mobiles 9.To see chip open your phone and see on main big blask ic the name. 10.Press Power Button and then Press Find it button. 11. This will give you a message that you should press Power button and Hold on 12.Pins will be detected then Press set button 14. Open main shell, select your phone type, select model and then do your all jobs If this do not solve your problem then there is hardware problem in the phone best regards farimarwat |
08-31-2009, 12:10 | #9 (permalink) |
Member: 709520 Status: Offline Thanks Meter: 275 | still i tried 20 phones. but no success. only rx led blinking. but it connected to the pinfinder with out any problem. pls help me experts. i bought that box for 450 us dollar. no warranty sir. help me. pls |
08-31-2009, 22:25 | #10 (permalink) | |
What phone you have tried to connect ? What cable you have used ? What COM port you have selected ? | |
09-02-2009, 04:24 | #11 (permalink) |
Member: 709520 Status: Offline Thanks Meter: 275 | i was tried 4 vodafone 225 phones. i connected to left side com port. i try with pinfinder cable also. also i try soldering rj45 cable to test point. only RX blue led was blinking . motorolla c168, cnokia 6300 etc. all phones working well. i was switch bitween m-bus mode and f-bus mode no success . i do not want to know how to flash, unlock the phone only need connect one phone with the infinity . it is my dream now. no warranty to the box. i changed the letancy timer to 4. beleive me i like very much to see the TX led blinking. but infinity box connect to the pin finder pls help me infinity team. now i am confused |
09-02-2009, 06:55 | #12 (permalink) | |
2. connect box to PC according to this pictures: http://forum.gsmhosting.com/vbb/show...67&postcount=3 3. back side box power: set to UP position 4. back side USB port: connect to PC USB port 5. front side F-Bus/M-Bus: set to UP position 6. cable should be connected to left RJ-45 socket 7. DO NOT connect PinFinder to box for now, it's too complicate for you to use PinFinder at your first try. 8. if you have Vodafone-225 cable in package (cable with 8 pins) you must connect this cable to box and to phone 9. if you do not have this cable, take any RJ45 cable, leave only RJ45 connector and rx/tx/gnd wires and solder Rx/Tx/Gnd wires to Vodafone-225 according to information from Infinity-Box Shell. 10. run Infinity-Box Pana01 module 11. select Vodafone-225 model 12. press "unlock" button 13. press and hold phone "power" button and see that unlock done in several seconds I hope now you have a success | |
09-02-2009, 13:56 | #14 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | keyboard top 1..........8 1: box Rx/phone Tx (RJ45 pin-3) 2: box Tx/phone Rx (RJ45 pin-2) 3: Gnd Also you can see where is GND at "Cable picture #2", "Cable picture #3", "Cable picture #4" |
09-03-2009, 04:43 | #15 (permalink) |
Member: 709520 Status: Offline Thanks Meter: 275 | infinity soft recognise 3 ports . com0 serial port, com1serialport, com14vcpo. i select com14. then what is com0,com1,? is there driver problem in my machine?. but pinfinder connecting successfully though infinity box.hlep me?thankyou for helping me infinity support step by step. i think i am now one step a way to connecting a phone with infinity successfully |
Some basic questions, very basic :::ANSWERED::: | Caledonian | PolarBox 3 | 1 | 06-03-2009 13:44 |
Need Visual Basic 5.0 decompiler... | OrbiTel | Off Topic Zone | 2 | 07-24-2001 08:17 |
visual basics v6 | white van man | Alcatel & TCL Old Models | 2 | 07-17-2001 17:33 |
I'm a newbie - where can I get basic facts about flashing phones ? | The Villan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-04-2001 21:45 |
unlocking basics | vampire | Alcatel & TCL Old Models | 2 | 07-10-2000 22:34 |
