10-11-2014, 17:09 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: budaun Age: 38
Member: 702572 Status: Offline Sonork: 9837200009 Thanks Meter: 74 | battery is fully charged error Chinese Miracle II [MTK module] v 1.02 Operation : Format FileSystem [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 42 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 009800BC009000660076001500010000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x007F , [TOSHIBA] TYBC0A111557KC [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0015 0001 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Error read initial info , blank flash or wrong settings? Operation Failed Elapsed: 00:00:23 Reconnect Power/Cable! |
10-11-2014, 18:10 | #2 (permalink) |
No Life Poster Join Date: Apr 2008 Location: India
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Post phone identity logs As today I found a set & give me same error From that I can say phone flash id. not supported Dzirt will make it supported just wait Don't post ur box serial no it can be causes ur block box Br Vijay2u2 +Life is all abt Money + |
10-12-2014, 08:05 | #3 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | This flash is supported also in alternate way : Remove battery. Press Read Info in CM2. Press and hold Vol+ and Vol- , while holding them - insert cable. Say result after. |
10-12-2014, 09:33 | #4 (permalink) |
Member: 702572 Status: Offline Sonork: 9837200009 Thanks Meter: 74 | chq this but notwork sat is ok & on my sat same error Card found: S/N 085E:0128 Chinese Miracle II [MTK module] v 1.02 Operation : Check / Read Info [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 42 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 009800BC009000660076001500010000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... NAND FlashIC initialized [NAND] : FLASH_VEN : 0x007F , [TOSHIBA] TYBC0A111557KC [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0015 0001 [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Info read not done Erased phone or unsupported FlashIc? Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
10-12-2014, 10:35 | #5 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Please, enough post other tools logs. They give completely nothing for me. Download CM2MTK_v103 and work with your phone. Change exe in current CM2 folder. |
10-12-2014, 10:40 | #6 (permalink) |
Member: 702572 Status: Offline Sonork: 9837200009 Thanks Meter: 74 | Card found: S/N 085E:0128 Chinese Miracle II [MTK module] v 1.03 Operation : Check / Read Info [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 42 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage Error : Correct DA sequence not found for target! Boot Error! Operation Failed Elapsed: 00:00:04 Reconnect Power/Cable! |
