Old 01-12-2010, 13:49   #1 (permalink)
Member: 270521
Sonork: 100.15962233
Thanks Meter: 369
vodafone 541 unlock problem
hi i have tried to unlock vodafone 541 but after the whole process its still locked i'm using the latest exe mm 3.02 and for that i have even flashed the phone with a sim free file it says everything successfull but still locked wt can be wrong plz .
the file which i flashed with: 708X-2CALRU1-16E_XN16BN24_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAU I_08A_W08_40_SP1_V32_2009-08-28_En_Fr_De_Ru_Ua_simfree.B0M.bin
The Following User Says Thank You to faisal_sherry For This Useful Post:
Old 01-13-2010, 01:35   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
What is exact text that you can see at phone LCD when you power-on phone with SIM card ?
Also I suggest you to read this: http://forum.gsmhosting.com/vbb/show...=858937&page=5
Old 01-13-2010, 14:14   #3 (permalink)
ZIYAAD STRYKER's Avatar
Member: 175945
Sonork: ziiyyaad
Thanks Meter: 704
i tried to connect phone with pin finder with l10c cable selecting c701 pinout still not connecting!!! can any 1 help please?
Old 01-13-2010, 15:27   #4 (permalink)
Member: 130995
Hello,
Double check that cable inserted well into phone connector.
In case of problems you can use test-points (Rx/Tx/Gnd) at phone back side under battery.
Old 01-14-2010, 13:43   #5 (permalink)
Member: 270521
Thanks Meter: 369
Originally Posted by InfinitySupport View Post
Hello,
the phone says SIM card locked! SOS calls only! but the problem is its not even accepting vodafone simcard the one which came with it i flashed the phone with this (708X-2FVDHU1-17C_XN17FJ83_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAU I_08A_W08_40_SP1_V32_2009-09-16_En_Hu_Ro_Cz_Sk_Vodafone-541.B0M.bin) firmeware from support and it came up with vodafone ok then i unlocked it and it worked on orange and vodafone, but when i changed the card it went back locked again on everyhing even on vodafone. wts wrong thanks
br
Old 01-14-2010, 13:55   #6 (permalink)
irfanboss's Avatar
Member: 256247
Thanks Meter: 444
708X-2FVDGB1-17B_XN17FC75_JRDSZ25_08A_PCB01_GPRS_MT6225_S00[1].MAUI_08A_W08_40_SP1_V32_2009-09-10_En_Fr_Es_It_De_Vodafone-541.B0M
flash this file an unlock in infinity box then ur problem is soulf 100%
Old 01-14-2010, 15:58   #7 (permalink)
Member: 270521
Thanks Meter: 369
i have just flashed the phone with this file 708X-2FVDGB1-17B_XN17FC75_JRDSZ25_08A_PCB01_GPRS_MT6225_S00[1].MAUI_08A_W08_40_SP1_V32_2009-09-10_En_Fr_Es_It_De_Vodafone-541.B0M and unlocked it after for the first time i turned on with tmobile sim card it worked then i put vodafone back and its locked. Now phone is again not accepting any simcard wtsoever
br
Old 01-15-2010, 09:43   #8 (permalink)
Member: 270521
Thanks Meter: 369
Anyone from support???
Old 01-15-2010, 16:48   #9 (permalink)
Member: 130995
1. stopt to flash phone without any reason. Just make "sp-unlock" button
2. you must read this: http://forum.gsmhosting.com/vbb/show...=858937&page=5
3. TEST PHONE WITH GOOD SIM CARD THAT CAN GET NETWORK !!! DO NOT USE OLD SIM-CARDS THAT IS NOT ACCEPTED BY NETWORK !!!
Old 04-21-2010, 13:13   #10 (permalink)
Member: 637642
Sonork: 1610072
Thanks Meter: 47
Voda Fone 541 unlock done
COM8 [VCP0] selected
module v3.03
Device: Vodafone-541
Checking data, wait...
Action: rebuild security area
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001203:A002
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 98006F00000003:09EA0000000000
flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader (chip) is present: 00020000
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is present
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.432E9 B93.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_E8F450A0].rpl
rom info detection finished
TCL-ID detection...
TCL-ID detection done
device-id: 432E9B93
rom info ver: 07
sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN
project-id: MAUI.08A.W08.40.SP1.V32, A050F4E8
code offset: 00020000
ffs offset/size [01]: 01800000/00800000
TCL-ID identification
version: 17B
provider: 708X-2EVDGB1
customization: CN17FC75
customization: XN17FC75
TCL-ID identification done
TCL-ID is present
ffs/eeprom address assigned: 01800000
startup code area #1 check...
startup code area #1 fixed
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
product id: JRDHUIZHOU_MT6225_OTMINI_SERIES
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
searching sec info#2...
search sec info#2 finished
sim-lock status: enabled
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#3...
search sec info#3 finished
area1 is valid
area2 is valid
area3 is valid
area4 is valid
number of sec info areas: 3
security area (sec info, part #2) calculation...
error: security area (sec info, part #2) header is invalid
security area (sec info, part #1) calculation...
..................security area (sec info, part #1) detecting size...
security area (sec info, part #1) detecting parameters...
security area (sec info, part #1) encoding...
done
Write: security area (sec info, part #1)
security area (sec info, part #1) calculation done
identification header detected
customization name adjusted
Write: security area (sec info, part #2)
security area (sec info, part #2) calculation done
done
done
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
original imei: 00000000000000
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_432E9B93_E8F450A0_20100421-170047.B0X.bin
Finished, time used: 6 min 3 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
The Following 2 Users Say Thank You to .::ali-1::. For This Useful Post:
Old 05-03-2010, 14:13   #11 (permalink)
.::Zafar Communication::.'s Avatar
Member: 71045
Thanks Meter: 19
COM6 [VCP0] selected
module v3.25
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
chip: 0001:7903:A00A
status: 01
Boot Done
otp offset: 01FE0000
Initialize Done
====> Set baud ...
230400
Set baud Done
TCL-ID is absent
startup code area #1 backup saved: F:\InfinityBox\MModule\backup_security\id.F8CEECD2 .[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_E8F450A0].rpl
device-id: F8CEECD2
rom info ver: 07
TCL-ID is absent
security area (sec info, part #1) size is incorrect: FFFFFFFF
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
sim-lock status: disabled
area1 is valid
area2 is valid
area3 is valid
area4 is valid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
error: security area (sec info, part #1) header is invalid
error: can't calculate security area (sec info, part #1)
done
done
original imei: 35400703510353
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: F:\InfinityBox\MModule\backup_security\Vodafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_F8CEECD2_E8F450A0_20100503-054632.B0X.bin
Finished, time used: 4 min 39 sec
after power on about 2 ,3 minute phone does not power on please comments what is wrong
thanks & regards
zafar Janjua
The Following User Says Thank You to .::Zafar Communication::. For This Useful Post:
Old 05-03-2010, 14:18   #12 (permalink)
AHMAD WAQAS's Avatar
Member: 808672
Sonork: 100.1612406
Thanks Meter: 83
unlock also without problem
log opened: [5/3/2010 1:32:15 AM] ====
Application: C:\Program Files\InfinityBox\MModule\MModule.exe
Loading data, wait...
[Infinity Box] MModule v3.03
S/N: 418C:0116
Wait...
Done
==== log: [5/3/2010 1:32:27 AM] ====
COM4 [VCP0] selected
module v3.03
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
chip: 0001B03:A009
status: 01
Boot Done
Initialize Done
====> Set baud ...
115200
Set baud Done
TCL-ID is present
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.C6279 180.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_E8F450A0].rpl
TCL-ID detection...
device-id: C6279180
rom info ver: 07
version: 17B
provider: 708X-2EVDDE1
customization: CN17FB75
customization: XN17FB75
TCL-ID is present
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
done
done
done
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_C6279180_E8F450A0_20100503-013839.B0X.bin
Finished, time used: 5 min 55 sec
The Following 2 Users Say Thank You to AHMAD WAQAS For This Useful Post:
Old 05-04-2010, 12:12   #13 (permalink)
Member: 1043909
Thanks Meter: 60,926
@.::Zafar Communication::.
Try to make "Repair security area" operation.
What is the results ?
Also, do not forget to check battery voltage.
Old 05-29-2010, 14:57   #14 (permalink)
srkhan's Avatar
Member: 153695
Sonork: srkhan
Thanks Meter: 788
Vodafone 514 Unlock
Forget Pin-finder, just do as bellow image shown...
Old 05-29-2010, 19:52   #15 (permalink)
unicomtogo's Avatar
Member: 660737
Thanks Meter: 105
I Have in hand a vodafone 541 for unlock. as show in picture here; i try to connect cable to rx tx and gnd; when unfortunately; rx point remove from the phone.
can i find inside the phone a point or another rx connection.
this is very urgent coz customers is behind me
VODAFONE 541 Unlocking irfan99 Infinity-Box 16 09-13-2014 14:04
please help vodafone 541 unlock david69 Infinity-Box 11 07-10-2010 14:04
Vodafone 541 unlock problem ..... [SOLVED] ramis_bcn PolarBox 3 5 02-10-2010 16:10
Alcatel 708x / Vodafone 541 Unlocking [ANSWERED] celfat PolarBox 3 8 01-30-2010 16:01
Vodafone 541 unlock? Petyo Easy-Unlocker 16 12-10-2009 16:27
Page generated in 0.29814 seconds with 10 queries
