Old 06-06-2011, 07:03   #1 (permalink)
shahidm's Avatar
Member: 227428
Thanks Meter: 27
LG S310 Unlock Problem
Read Codes
COM5 [VCP3] selected
module v3.92
Action: read unlock codes
unlock method: read codes
Model: LG-GS310
Checking data, wait...
19200 autodetect
Initializing [6235:8B00:8A01]...
CPU: MT6235
chip: 0000:0000:0003
status: FF
rom: 4D573031
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6235B,E00
Date: 2000.00.00
Version: 1.0
Version: MAUI.09AW0944LGE_WISE_SP.W10.32
Version: ROSEMARY_HW
115 byte(s) read
connection Ok
217 byte(s) read
38 byte(s) read
Phone lock: Off
Phone code: 1122
205 byte(s) read
reading data...
188 byte(s) read
lock[1] code: - default
lock[2] code: - default
lock[3] code: - 1122
lock[4] code: - default
lock[5] code: - default
lock[6] code: - default
lock[7] code: - default
if code is not accepted by phone:
- insert wrong sim card into phone
- power-On phone
- enter code: 12345678
- wait 10 seconds
- power-Off phone via "Power" button (do not remove battery)
- read unlock codes again
Finished, time used: 16 sec
Remove/Install battery now !
Smart Fast
module v3.92
Action: "sp-unlock"
unlock method: smart fast
Model: LG-GS310
19200 autodetect
CPU: MT6235
status: FF
rom: 4D573031
Date: 2000.00.00
Version: 1.0
115 byte(s) read
connection Ok
217 byte(s) read
reading data...
reading data #2...
building new data...
writing data...
205 byte(s) read
reading data...
188 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 22 sec
Both Method Not Work
Plz Infinity Team Help To solve This Problem
I Follow All instruction,,
BR,
Shahid Mahmood
Old 06-06-2011, 07:06   #2 (permalink)
Faheem Anjum's Avatar
Member: 399832
Sonork: Faheem Anjum
Thanks Meter: 24,310
read full flash and upload here to check
Old 06-06-2011, 09:35   #3 (permalink)
shahidm's Avatar
Member: 227428
Thanks Meter: 27
Here is Readed File and Operation Log
module v3.92
Device: LG-GS310
Action: read flash NAND
interface: BROM_DLL_v3.1016.00
Connect...
Connecting...
Booting...
bootcode current/expected: 3.2/3.2
CPU: 6235:8B00:8A00
status: FF
bbchip bl ver: FE
NOR flash chip: not installed
NAND flash id[0008]: 00EC:00B100000055 [SAMSUNG] K9F1G16Q0M
chip size: 128Mb
page/spare size: 0800/0040
pages per block: 0040
bits i/o: 10
address cycles: 04
internal RAM size: 00010000
external RAM: absent
done
Set baudrate (921600)...
done
interesting cpu type found: 6235:8B00:8A00
ram test...
testing 32bit...
32bit ram test passed
testing 16bit...
16bit ram test passed
ram test passed
===> detect existing firmware structure...
detect ffs...
ffs offset/size: 01800000/06800000
firmware size: 24Mb
ffs size: 104Mb
detect sec ro...
detect custom parameters...
detect project-id...
project-id: MAUI.09AW0944LGE_WISE_SP.W10.32
detect NAND info...
number of areas/bytes to read: 1:001A0000
reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)...
nfi area detection...
incorrect ext bootloader signature: A94810B5
bootloader version: ROSEMARY_BOOTLOADER_V005_MT6235B_MAUI_09AW0944LGE_ WISE_SP_W10_32
nfi area detection (2 cores) finished: Ok
warning: ffs can not be detected
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
startup code area #1 detection done
rom info ver: 07
sw version: ROSEMARY_PCB01_GPRS_MT6235B_S01.MAUI_09AW0944LGE_W ISE_SP_W10_32.BIN
project-id: MAUI.09AW0944LGE_WISE_SP.W10.32, 00000000
code offset: 00000000
rom info structure: [standard] type (07)
TCL-ID is absent
===> done
area size: 128Mb
number of areas/bytes to read: 1:08000000
file saved: C:\Documents and Settings\Shahid\Desktop\LG-GS310_ROSEMARY_PCB01_GPRS_MT6235B_S01.MAUI_09AW094 4LGE_WISE_SP_W10_32__fullflash_20110606-124152.B4M.bin
Disconnect...
done
Finished, time used: 46 min 19 sec
LG-GS310_ROSEMARY_PCB01_GPRS_MT6235B_S01.MAUI_09AW094 4LGE_WISE_SP_W10_32__fullflash_20110606-124152.B4M.zip - 4shared.com - online file sharing and storage - download
Old 06-14-2011, 21:11   #4 (permalink)
Proxy's Avatar
Member: 66399
Thanks Meter: 42
Phone unlock problem solved!
but it isnt easy
first of all , write flashfile from support which kills the phone ( probably these phones which doesnt unlock as intended are with "new , protected fw ")
then with Gsmmulti write original lg fw ( phone is alive but with defailt imei )
and finally - repair imei with Infinity , and all done
Old 10-31-2011, 10:33   #5 (permalink)
sunnyarora's Avatar
Member: 483406
Thanks Meter: 180
which cable use or any test point
Old 10-31-2011, 11:01   #6 (permalink)
syed jewel's Avatar
Member: 1067276
Sonork: 100.1591989
Thanks Meter: 654
which cable use
Use Gs 102
it
Old 11-04-2011, 05:08   #7 (permalink)
Member: 599037
Thanks Meter: 103
it is gs 310 man not s310.. plz mantion correct name always..
Old 11-17-2011, 17:32   #8 (permalink)
Member: 33954
Thanks Meter: 10
tested not work phone remaing locked after all steps
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 03-23-2015 14:21
Page generated in 0.15610 seconds with 9 queries
