BEETEL EC005 by BSNL BEETEL EC005 this phone is provided by BSNL HERE IS EEPROM AND BACK UP FULL FLASH http://www.mediafire.com/?xyndxoymng2 http://www.mediafire.com/?ntmojw2mlht in screen its showing phone lock: i am able to read phone by selecting beetel ec003 how to unlock this phone read general information Action: read information Model: Beetel-EC003 Checking data, wait... Phone should be Switched ON ! Connecting, wait... baud set to: 57600 Phone detected, wait... Hardware version: MT6205B, E0 Hardware version: KONKA_NEP_COLOR_05C_HW Software version: KAA625A_INE_EN_HI_1. Software date: 2003.07.29 Barcode: 911030442 imei: 357039017021103 Finished, time used: 10 sec Power off phone now ! please help to unlock this phone |
Hello, Did you tried to make "unlock" via "read codes" method ? It is safe procedure. What is the results ? What is this phone pinout ? |
Tryed read code safe format complite format direct unlock smart unlock but phone still locked phone showing phone lock code with out sim |
Hello, Please, download latest MModule v2.44 from support area and try to make unlock (EC005 model) in "standard" mode. Waiting for results. |
THANKS PHONE UNLOCKED SUCESSFULLY COM3 [VCP0] selected module v2.44 Device: Beetel-EC005 Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "sp-unlock" unlock method: standard Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6205:8B00]... CPU: MT6205 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: C625_BEETEL_PCB01_GSM_MT6205B_DN.KAA625A_INE_EN_HI _1_12_607.BIN ver. sw 2: KAA625A_INE_EN_HI_1.12.607, 00000000 ffs offset/size: 00300000/00100000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[C625_BEETEL_PCB01_GSM_MT6205B_DN.KAA625A_INE_EN_HI _1_12_607.BIN]... file saved: C:\Program Files\InfinityBox\MModule\eeprom[C625_BEETEL_PCB01_GSM_MT6205B_DN.KAA625A_INE_EN_HI _1_12_607.BIN]_20081119-223105.B0E.bin flash: 01227E221A2201:18E59F00000000 Backup required data Done Patch required data ... detection procedure, wait... detection procedure completed Patch required data Done Special operation ... detecting additional parameters... ..... flash: 01227E221A2201:18E59F00000000 flash: 01227E221A2201:18E59F00000000 Write: area 0/1 ......... flash: 01227E221A2201:18E59F00000000 flash: 01227E221A2201:18E59F00000000 Write: area 0/2 flash: 01227E221A2201:18E59F00000000 flash: 01227E221A2201:18E59F00000000 Write: area 0/3 flash: 01227E221A2201:18E59F00000000 flash: 01227E221A2201:18E59F00000000 Write: area 0/4 flash: 01227E221A2201:18E59F00000000 flash: 01227E221A2201:18E59F00000000 Write: area 0/5 flash: 01227E221A2201:18E59F00000000 flash: 01227E221A2201:18E59F00000000 Write: area 0/6 flash: 01227E221A2201:18E59F00000000 flash: 01227E221A2201:18E59F00000000 Write: area 0/7 .. additional parameters detected Ok Special operation Done Write ... flash: 01227E221A2201:18E59F00000000 Write: eeprom Write Done Finalization ... Finalization Done Finished, time used: 83 sec Remove/Install battery now ! |
Hello, Thanks a lot for test report ! We have released update for this model: http://forum.gsmhosting.com/vbb/showthread.php?t=633572 |
I have ec005 i want the picture of rx tx gnd in the board help? |
Rx/Tx points should be marked at PCB. Did you tried to open phone to check it ? |
yes i have opened the phone but there is no where written rx tx gnd |
Hello, Please, post here good quality PCB photo. |
As i remember check below sim trey. There r some test points and find out rx tx and gnd by voltage measurement method THERE IS NOT WRITEN AS RX TX GND. U HAVE TO FIND |
thanks for info i-Care |
sorry for repost internet error |
