Old 10-08-2007, 07:21   #1 (permalink)
Member: 426680
Thanks Meter: 11
Motorola c261
I have c261. It was on contact service Provider. I flashed it. then it started restarting, then i flshed with differ version, restarting stoped and now it is giving signal problem. First time flashed log file is as under:
COM3 [VCP1] selected
"smart write" active
Action: flash
Write: Firmware
Write: Language Pack
Write: Flex
Skip: Eeprom
Device: C261
Checking data, wait...
Connect...
Press and HOLD Power button...
Connecting...
initial boot phase complete
Release Power button !
Connect Done
Boot...
Boot Done
Set Baud...
115200
Set Baud Done
Check Flash-1...
SW version: 0.1.76
HW version: MOTOROLA_E58S
LP ver: LPNA_0176
Flex ver: FLEX_90_64_5009
cpu id: 08B6
imei eeprom: 01091100594796
required SW version: 0.1.76
sp-locked: 302720302370
You want to write Flex in sp-locked[302720302370] phone,
Make this only when you understand what you want to do !
Are you sure you want to continue ?
user confirmed Flex write operation for sp-locked phone
Check Flash-1 Done
Check Flash-2...
reading ...
file saved: backup_eeprom_calibration_01091100594796_20071008-040448.34E.bin
Check Flash-2 Done
Write...
Writing: Firmware
Writing: Language Pack
Writing: Flex
Write Done
Finished, time used: 1368 sec
Remove/Install battery now !
After that i flashed again it flashed successfully and now it is giving signal problem:
COM3 [VCP0] selected
Action: flash
Write: Firmware
Write: Flex
Skip: Eeprom
Device: C261
Connect...
Connecting...
Connect Done
Boot...
Boot Done
Set Baud...
460800
Set Baud Done
Check Flash-1...
SW version: 0.1.76
LP ver: LPNA_0176
Flex ver: FLEX_90_64_3903
cpu id: 08B6
Check Flash-1 Done
Check Flash-2...
reading ...
file saved: backup_eeprom_calibration_01091100594796_20071008-225922.34E.bin
Check Flash-2 Done
Write...
Writing: Firmware
Writing: Flex
Write Done
Finished, time used: 520 sec
Inifnity Team: Plz help me to slove this problem
WAITING FOR QUICK REPLY
Old 10-08-2007, 07:52   #2 (permalink)
gs cell's Avatar
Member: 308822
Thanks Meter: 380
https://forum.gsmhosting.com/vbb/f296/c261-after-flash-sim-not-valid-395582/
Old 10-08-2007, 08:05   #3 (permalink)
Registered User
Member: 572549
Thanks Meter: 175
use version 0.1.66 bro........ your problem is solved
Old 10-08-2007, 11:53   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
@ziasim
our phone is from America.
Check what band used in your country
UPDATE 03 Feb 2006: Motorola C261 model support InfinitySupport Infinity-Box 43 06-05-2007 05:22
motorola c261 blinks ToP DawG Infinity-Box 3 06-23-2006 22:06
Finally Motorola C261 Direct Unlock Solution has been released Infinity-Box Motorola ODM 0 05-22-2006 08:58
Motorola C261 DJiCE PolarBox 1 1 04-28-2006 15:21
unlock simlock motorola c261 maxitel Infinity-Box 13 04-25-2006 11:35
Page generated in 0.15355 seconds with 9 queries
