Benq E61 problem hi all... i've a problem on repairing Benq E61, the phone can not receive and sent SMS, i've reset setting but the problem not solve, so i try to flash the phone with : E61_Main_v140.7FM E61_LP_v140_0011_LP_En_CnS_CnT_Melayu.7FP E61_Flex_v140_0011_Tw.7FF But i receive error when flashed the phone, i've try to change with other version (3 times), i've been used fully of charge Battery, try to use with power supply, Now my phone is dead here is the log : Code: COM12 [VCP0] selected What's the problem of my phone ?? please help me..:( |
Hello, Try to flash phone this way: 1. run HModule.exe 2. select model "Hercules 16Mb" 3. flash phone Also it can be a hardware problem, f.e. water inside or bad soldered flash chip. |
Hi InfinitySupport, Thank's for your fast reply, I've try to run Hmodule.exe (V 1.12), there is no model "Hercules 16M", it just shown Alcatel, Konka, Motorola and Sony Ericsson Model. I'm still waiting another your suggestion. BR, |
Latest HModule version is 1.29. |
Benq e61 hang problam without sim set ok but start sim after two munite set hang how can solve Infinity team pls help. |
Hello InvinitySupport.. i've installed the latest update now and running Hmodule, selected "Hercules 16M" but it can not solve my problem, it's the LOG Quote:
anybody can help me..??? |
Hello, try to flash phone again like you have tried with first method. What will be the errors ? Do you see the errors at the same address ? |
in this case i'm not sure it a HW problem, when i'm flash it, infinity always show Code: error: Probably wrong model selected. |
Hello, Are you sure that you have used correct cable when you tried to connect phone via HModule ? As I can see you have used different cables. What was the reason to use other cable ? Did you tried to boot phone with HModule with the same cable as you have used before ? |
Hello, 1st log: COM12 [VCP0] selected 2nd log: COM1 [Serial0] selected As I can see from your logs you have used different cables and you have selected different COM ports. |
On HModule what firmware model that i should download on your support area ?? |
Hello, it's quite strange that phone can not be flashed. Please, try to use different "connection" methods from software "Settings" page and try to flash phone again. It may be good idea to write "repair eeprom" files but not firmware. Do not forget to make eeprom backup before this operation. |
