Old 11-15-2008, 21:31   #1 (permalink)
Unggul's Avatar
Member: 71273
Thanks Meter: 14
Benq E61 problem
hi all...
i've a problem on repairing Benq E61, the phone can not receive and sent SMS, i've reset setting but the problem not solve, so i try to flash the phone
with :
E61_Main_v140.7FM
E61_LP_v140_0011_LP_En_CnS_CnT_Melayu.7FP
E61_Flex_v140_0011_Tw.7FF
But i receive error when flashed the phone, i've try to change with other version (3 times), i've been used fully of charge Battery, try to use with power supply, Now my phone is dead here is the log :
COM12 [VCP0] selected
Device: BenQ E61
Checking data, wait...
Action: flash write
"smart write" active
Write: Firmware
Write: Flex
Write: Language Pack
Skip: Eeprom
Boot...
Press Power button now !
Connecting...
Boot Done
Check Connection...
Check Connection Done
Set Baud...
Set Baud Done
Check Flash...
error: Probably wrong model selected.
Continue anyway ?
Check Flash Done
Check Parameters...
Check Parameters Done
Check Space...
Flash: 0089:881200010001
flash: Intel 128MBit-T Strata T 16Mb
Check Space Done
Check Data...
Check Data Done
Erasing...
erase operation not required
Erasing Done
Writing...
Write: Firmware
error: answer#00
try#1 to recover erase error#00
error: answer#00
try#2 to recover erase error#00
error: answer#00
try#3 to recover erase error#00
error: answer#00
try#4 to recover erase error#00
error: answer#00
try#5 to recover erase error#00
error: answer#00
try#6 to recover erase error#00
error: answer#00
try#1 to recover write error at 00000000
...:confused:
What's the problem of my phone ?? please help me..
Old 11-15-2008, 22:04   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
Hello,
Try to flash phone this way:
1. run HModule.exe
2. select model "Hercules 16Mb"
3. flash phone
Also it can be a hardware problem, f.e. water inside or bad soldered flash chip.
Old 11-16-2008, 02:38   #3 (permalink)
Unggul's Avatar
Member: 71273
Thanks Meter: 14
Originally Posted by InfinitySupport View Post
Hello,
1. run HModule.exe
3. flash phone
Hi InfinitySupport,
Thank's for your fast reply,
I've try to run Hmodule.exe (V 1.12), there is no model "Hercules 16M", it just shown Alcatel, Konka, Motorola and Sony Ericsson Model.
I'm still waiting another your suggestion.
BR,
Old 11-16-2008, 09:57   #4 (permalink)
Member: 130995
Latest HModule version is 1.29.
Old 11-16-2008, 17:15   #5 (permalink)
Member: 224789
Thanks Meter: 19
Question Benq e61 hang problam
without sim set ok but start sim after two munite set hang how can solve
Infinity team pls help.
Old 11-16-2008, 20:16   #6 (permalink)
Unggul's Avatar
Member: 71273
Thanks Meter: 14
Hello InvinitySupport..
i've installed the latest update now and running Hmodule, selected "Hercules 16M"
but it can not solve my problem, it's the LOG
COM1 [Serial0] selected
Device: Hercules 16m
"advanced chip detection" active
Action: flash write
Write: Firmware
Skip: Flex
Skip: Language Pack
Skip: FFS/File system
Skip: Images
Skip: Melody
Skip: Eeprom
Boot...
Boot fail
Finished, time used: 11 sec
Remove/Install battery now !
I'm not sure if it's a hardware problem. Another suggestion Infinity ??
Old 11-18-2008, 14:56   #7 (permalink)
Unggul's Avatar
Member: 71273
Thanks Meter: 14
anybody can help me..???
Old 11-18-2008, 16:23   #8 (permalink)
Member: 130995
Hello,
try to flash phone again like you have tried with first method.
What will be the errors ?
Do you see the errors at the same address ?
Old 11-18-2008, 21:10   #9 (permalink)
Unggul's Avatar
Member: 71273
Thanks Meter: 14
Hello,
yes, i have try it and showed the same error.
in this case i'm not sure it a HW problem, when i'm flash it, infinity always show
it makes me confused...
Old 11-18-2008, 23:59   #10 (permalink)
Member: 130995
Hello,
Are you sure that you have used correct cable when you tried to connect phone via HModule ?
As I can see you have used different cables.
What was the reason to use other cable ?
Did you tried to boot phone with HModule with the same cable as you have used before ?
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 11-20-2008, 16:05   #11 (permalink)
Unggul's Avatar
Member: 71273
Thanks Meter: 14
Hello,
with Hmodule i'm used the same cable sir.
Old 11-20-2008, 19:35   #12 (permalink)
Member: 130995
Hello,
1st log: COM12 [VCP0] selected
2nd log: COM1 [Serial0] selected
As I can see from your logs you have used different cables and you have selected different COM ports.
Old 11-21-2008, 13:21   #13 (permalink)
Unggul's Avatar
Member: 71273
Thanks Meter: 14
Hello,
i'm using Benq M300 Cable and try to use USB cable.
On HModule what firmware model that i should download on your support area ??
Old 11-21-2008, 14:51   #14 (permalink)
Member: 130995
Hello,
it's quite strange that phone can not be flashed.
Please, try to use different "connection" methods from software "Settings" page and try to flash phone again.
It may be good idea to write "repair eeprom" files but not firmware.
Do not forget to make eeprom backup before this operation.
Problem connect benq e61 Winston rio hum Infinity-Box 1 12-06-2009 18:07
Benq E61 Unlock Shady_Slim FuriousGold 16 12-06-2007 16:38
BenQ E61 reaz.com Infinity-Box 1 01-22-2007 18:06
BenQ E61 cable pinout reaz.com FuriousGold 3 01-22-2007 07:30
BenQ E61 cable reaz.com Infinity-Box 2 01-20-2007 19:26
Page generated in 0.41122 seconds with 8 queries
