02-14-2008, 10:48 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: player /-GSM-\ Field
Member: 161115 Status: Offline Sonork: Here you can find it... Thanks Meter: 3,039 | Benq M300 Flas Ok But POW Not On.....??? Log........... COM5 [VCP0] selected Device: BenQ M300, TCM Tchibo Checking data, wait... Action: flash write "smart write" active Write: Firmware Write: Flex Write: Language Pack Write: Eeprom Boot... Phone should be Switched OFF ! Connect test-point to Ground ! Press Power button now ! Connecting... Disconnect test-point ! Boot Done Check Connection... Check Connection Done Set Baud... 812500 Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:885500010001 flash: Intel 28F640W30-B B 8Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0089:885500010001 flash: Intel 28F640W30-B B 8Mb Write: Flex flash: Intel 28F640W30-B B 8Mb Write: Language Pack flash: Intel 28F640W30-B B 8Mb Write: Eeprom flash: Intel 28F640W30-B B 8Mb Writing Done Finished, time used: 110 sec Remove/Install battery now ! |
02-14-2008, 14:34 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, What is initial phone state ? Is it was dead or good working phone ? Did you tried to use different version flash files sets (Main + LP + Flex the same version) ? |
02-14-2008, 23:01 | #3 (permalink) |
Member: 161115 Status: Offline Sonork: Here you can find it... Thanks Meter: 3,039 | What is initial phone state ?dead.Did you tried to use different version flash files. no (Main + LP + Flex the same version) yes same. |
Nokia n95 (8gb) rm-320, full reset ok , but set not on & not flashing full | nakshatra | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 03-28-2010 07:50 |
7610 flash ok, but set not on and not show nokia after flashing | kashif_khatri | WD2 & APE (Symbian Phones) | 3 | 08-05-2009 08:42 |
1112 flashing ok but power not on | naveed malik | Nokia Hardware & Hardware Repair | 4 | 02-27-2007 14:16 |
1100 flashing ok but set not on ?????????? | moorthy | Nokia Hardware & Hardware Repair | 18 | 02-19-2007 03:52 |
w550 & 3230 full flash ok but pc not on | TechPhone | Universalbox | 6 | 04-28-2006 08:54 |
