06-19-2006, 21:04 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Age: 48
Member: 107916 Status: Offline Thanks Meter: 30 | BEnq M300 problem to unlock today i receive one benq M300 locked to bouygtelecom when put sim carte in side phone displayed enter net work code when unlock with infinity i just have this og opened: [19/06/2006] [14:19:22] App: C:\PROGRA~1\INFINI~1\BModule\BModule.exe [Infinity Box] v.1.07A Loading, wait... S/N: 0xxxxxx Wait... Current device: O2X1i,O2XLI Done Current device: BenQ M300 COM1 selected Device: BenQ M300 Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... FLASH: 0089:8855 Check Space Done Check Data... Check Data Done Erasing... Erasing Done Writing... Writing Done Finished Remove/Install battery now ! Time used: 56 sec COM1 selected Device: BenQ M300 Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Err: not locked or unknown eeprom Check Parameters Fail Finished Remove/Install battery now ! Time used: 60 sec and at end the phone still lock and try with furious same thing and at end always this message phone was not lock buy when put sim carte in side phone asked " code reseau" how can i unlock this phone please here i attached eeprom for this phone br leroi |
06-21-2006, 11:45 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | remove sim card 1. make unlock 2. remove battery 3. power on phone 4. power off phone 5. insert sim card 6. test phone also try to ask omebody what does it mean "code reseau" (I don't know this language so can't imagine what this means). After we will know what this words means we can understand what to do. |
06-21-2006, 20:19 | #5 (permalink) |
Member: 107916 Status: Offline Thanks Meter: 30 | hello code reseau mean " network code " phone after unlock ask unlock code i have already unlock it today and i made bach up flash for this phone Log opened: [21/06/2006] [17:58:23] App: C:\Program Files\InfinityBox\BModule\BModule.exe [Infinity Box] v.1.07A Loading, wait... S/N: 07B1:0108 Wait... Current device: O2X1i,O2XLI Done Current device: BenQ M300 COM1 selected Device: BenQ M300 Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Err: not locked or unknown eeprom Check Parameters Fail Finished Remove/Install battery now ! Time used: 62 sec COM1 selected Device: BenQ M300 Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Err: not locked or unknown eeprom Check Parameters Fail Finished Remove/Install battery now ! Time used: 65 sec COM1 selected Device: BenQ M300 Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Part 1 of 1... In progress... FLASH: 0089:8855 Finished Remove/Install battery now ! Time used: 1012 sec after this power one the phone power off the phone put sim card phone still asked " network code" i have attached here full back up for this phone and eeprom data http://rapidshare.de/files/23717593/...oblem.rar.html i thing this can help to fixe this problem br leroi |
06-21-2006, 22:30 | #7 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Quote:
If not yet, please, make it now and you can find there repair eeprom files for M300 (as well as for other models). | |
06-21-2006, 22:34 | #8 (permalink) | |
I'll inform you about results ASAP. Also you can try to write "Repair eeprom" in your phone. waiting for results. | |
06-22-2006, 20:39 | #10 (permalink) |
Member: 107916 Status: Offline Thanks Meter: 30 | hello [Infinity Box] v.1.07A Loading, wait... S/N: 0****** Wait... Current device: O2X1i,O2XLI Done Current device: BenQ M300 COM1 selected Device: BenQ M300 Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Err: not locked or unknown eeprom Check Parameters Fail Finished Remove/Install battery now ! Time used: 58 sec Loading... M300_repair_eeprom_02.3AE.bin Loaded COM1 selected Device: BenQ M300 Checking data, wait... Skip: Firmware Skip: Flex Skip: Language Pack Write: Eeprom Smart Write active Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... FLASH: 0089:8855 Check Space Done Check Data... Check Data Done Erasing... Erasing Done Writing... Write: Eeprom Writing Done Finished Remove/Install battery now and at end phone is unlock thanks for advice leroi |
06-28-2006, 11:57 | #12 (permalink) | |
07-29-2006, 00:50 | #13 (permalink) |
Freak Poster Join Date: Feb 2005 Location: Pakistan Hyderabad Age: 39
Member: 117640 Status: Offline Sonork: 100.1580505 Thanks Meter: 62 | M300 unlock problem need help whan i unlock error is this COM3 selected Device: BenQ M300 Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Err: [03] Boot Fail Finished Remove/Install battery now ! Time used: 10 sec need help urgent |
07-29-2006, 07:07 | #14 (permalink) | |
Check support area to se TestPoint picture. | |
07-31-2006, 05:39 | #15 (permalink) |
Member: 117640 Status: Offline Sonork: 100.1580505 Thanks Meter: 62 | COM3 selected Device: BenQ M300 Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Err: not locked or unknown eeprom Check Parameters Fail Finished Remove/Install battery now ! Time used: 56 sec currupted eprom area i download eprom from support area and chack but stil currupted eprom . phone sw/hw: v1.35-1 this version eprom is not available in support area need help urgent thanks |
Benq M300, TCM Tchibo unlocking with foulty cable | huzsolt | Infinity-Box | 0 | 12-03-2006 18:18 |
Benq ap75 how to unlock? | uti79 | NON Siemens Brand (ODM Phones) | 1 | 08-05-2006 18:09 |
benq Z2 How to unlock !!???? | humbedj | Various | 0 | 04-02-2006 18:18 |
BENQ S660c, how to unlock this phone? | mourad_t | Various | 4 | 08-22-2005 16:15 |
benq m300 problems | prabue | Redbox | 2 | 07-21-2005 05:30 |
