06-18-2006, 20:02 | #1 (permalink) |
Registered User Join Date: Apr 2006
Member: 256736 Status: Offline Thanks Meter: 22 | Benq M300 Unlock User Code Problem. Device: Benq M300, TCM Tchibo Checking data, wait Action: User code Boot Phone should be switched off connect test point to ground press power button now err: boot error (02) disconnect test point boot fail Finished Remove/install battery now Time used: 48 sec. Com 4 is working fine with others phones. Which is the test point in this M300 phones? Support can help me? Thanks. |
06-19-2006, 08:17 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, Testpoint is the same as like for o2x1i/b. Also you can download latest version of BModule from support area "Beta/test software" section and try it (no need test point for user code in this latest release). |
06-19-2006, 17:57 | #3 (permalink) | |
Member: 256736 Status: Offline Thanks Meter: 22 | uSED bMODULE V112.A Quote:
I used Bmodule Beta test V1.12A and phone not detected: Current device: Benq M300, TCM tchivo Com4 ready Com 4 selected Phone must be switched on connecting err: phone no detected, try again err: operation failed, try again. I tried many times and the same. Com 4 cable is connecting others phones I used M300 Uni benq cable, it comes with a thin red cable, what for is it? Thanks Infinity support. | |
06-19-2006, 22:30 | #4 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,227 | switch on phone and try again. red wire: did you read my prewious message about test-point picture ? can you try to read info from "Documentation" folder ? Quote:
06-19-2006, 23:00 | #5 (permalink) | |
Member: 256736 Status: Offline Thanks Meter: 22 | Problem Solved. Quote:
Com 4 selected Phone must be power on... connecting... connection ok.. Model : 56e11_j11... done. codes 1234/1234/1234 Power off phone by power button.. (Dont remove battery). | |
10-17-2006, 00:59 | #7 (permalink) |
No Life Poster Join Date: Apr 2005
Member: 137582 Status: Offline Thanks Meter: 93 | I have a problem on uiser code too: Loading data, wait... S/N: xxxx:xxxx Standard firmware detected Wait... Current model: O2X1i,O2XLI Done Current model: BenQ M300, TCM Tchibo COM3 selected Phone must be switched ON ! Connecting... Connection Ok Model: ERROR Codes: 1234/1234/1234 Done Power-Off phone by Power button (don't remove battery) After this, phone is still locked. I'm new to infinity, any help? Thanks! |
01-23-2009, 15:35 | #9 (permalink) |
Freak Poster Join Date: Jul 2005 Location: pondicherry,INDIA Age: 47
Member: 165982 Status: Offline Thanks Meter: 71 | m300 user code readed successfully(no needed test point) COM37 selected module v1.31 Phone must be switched ON ! Connecting... Connection Ok Model: 56E11_J11(O2) Codes: 1234/1234/1234 Done Power-Off phone by Power button (don't remove battery) |
01-23-2009, 15:40 | #10 (permalink) |
The Following User Says Thank You to barani For This Useful Post: |
Benq M300 unlock solution ? | yassinov® | Various | 15 | 08-27-2013 17:44 |
who have the benQ m300 master reset code?? | acelai00 | NON Siemens Brand (ODM Phones) | 3 | 06-18-2006 09:54 |
Benq M300 universal network code!! | OCTOPUS d.o.o. | Phone Unlocking Codes & Maps | 0 | 12-28-2005 10:51 |
need benq m300 unlocking software | AelafSoft | Various | 2 | 04-08-2005 21:26 |
Benq M300 Unlock ??? | casacentregsm | Various | 6 | 03-06-2005 18:21 |
