08-23-2006, 15:38 | #1 (permalink) |
Registered User Join Date: Aug 2005 Location: www.siamgsmunlock.com
Member: 175926 Status: Offline Thanks Meter: 25 | Benq M315 Cannot Flash FIST TIME I FLASH OK BUT PHONE SHOW MASSAGE no SERVICE AFTER INSERT SIM AND POWER ON HOW CAN I DO.THANK COM5 selected Device: BenQ M315, Siemens AP75 Checking data, wait... Action: Flash write Smart Write active Write: Firmware Write: Flex Skip: Language Pack Write: Eeprom Boot... Phone should be Switched OFF ! Connect test-point to Ground ! Press Power button now ! Connecting... Disconnect test-point ! Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Err: unknown flash chip: 0010:0010:0010:0010 Err: unknown flash chip: 1470:5571:5438:0020 Err: unknown flash chip: 3200:3200:3200:2200 Check Space Fail Finished Remove/Install battery now ! Time used: 36 sec WHEN I UNLOCK COM5 selected Device: BenQ M315, Siemens AP75 Checking data, wait... Action: Unlock Boot... Phone should be Switched OFF ! Connect test-point to Ground ! Press Power button now ! Connecting... Disconnect test-point ! Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Err: unknown flash chip: 0010:0010:0010:0010 Flash: 0089:885500010001 file saved: Backup_eeprom-00_2006-8-23_21-41-9.4BF.bin Err: not locked or unknown eeprom Check Parameters Fail Finished Remove/Install battery now ! Time used: 38 sec Last edited by janjaroen; 08-23-2006 at 18:06. |
08-24-2006, 06:25 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, I think you have a reason to check phone hardware (maybe rehot flash chip) because strange things appeared during flash chip type detection. |
Benq M315 Restart After Flashing | alamgarh | Infinity-Box | 2 | 02-23-2008 14:00 |
BenQ M315 ,locked user code | pphone | Various | 4 | 06-12-2007 08:11 |
Benq M315 can flash with furious gold? | bestncheap | FuriousGold | 3 | 09-23-2006 17:13 |
Benq M315 Flashing | Nasmi | VygisToolbox | 1 | 08-04-2006 15:35 |
Benq M315 Unlock | shockboy | FuriouS II | 1 | 10-05-2005 18:20 |
