10-01-2009, 20:52 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: algeria BBA BELIMOUR Age: 46
Member: 184351 Status: Offline Thanks Meter: 263 | benq s660 error: unknown flash chip module v1.33 Device: BenQ-S660C Checking data, wait... Action: read flash Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 812500 Set Baud Done Check Flash... error: Probably wrong model selected. Continue anyway ? Check Flash Done Check Parameters... part 1 of 2... Reading... Flash: 0020:88BBFFFFFFFF file saved: D:\Program Files\InfinityBox\BModule\full_part_1_of_2_2009100 1-204304.78X.bin part 2 of 2... Reading... error: unknown flash chip: 0089:88CC:0001:0001 Flash: 0020:88BBFFFFFFFF file saved: D:\Program Files\InfinityBox\BModule\full_part_2_of_2_2009100 1-204532.78X.bin Finished, time used: 267 sec Remove/Install battery now ! can i unlock it using sp unlock ? or i must send you readed flash or what i can do ? |
10-02-2009, 09:30 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Try to unlock phone at 115200, let's see results. If phone can not be unlocked at 115200, we need to make support for this kind of hardware (flash chip), but we need to have this phone on hands for this kind of work. |
10-02-2009, 09:49 | #7 (permalink) |
Member: 184351 Status: Offline Thanks Meter: 263 | phone unlocked successfully thank you COM6 [VCP0] selected module v1.33 Device: BenQ-S660C Checking data, wait... Action: unlock Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... error: Probably wrong model selected. Continue anyway ? Check Flash Done Check Parameters... Flash: 0020:88BBFFFFFFFF file saved: D:\Program Files\InfinityBox\BModule\eeprom-00_20091002-094530.78F.bin file saved: D:\Program Files\InfinityBox\BModule\eeprom-01_20091002-094545.78F.bin file saved: D:\Program Files\InfinityBox\BModule\eeprom-02_20091002-094556.78F.bin file saved: D:\Program Files\InfinityBox\BModule\eeprom-03_20091002-094604.78F.bin file saved: D:\Program Files\InfinityBox\BModule\eeprom-04_20091002-094612.78F.bin Check Parameters Done Check Space... Flash: 0020:88BBFFFFFFFF flash: ST M28W320CB B 4Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Flash: 0020:88BBFFFFFFFF Flash: 0020:88BBFFFFFFFF Flash: 0020:88BBFFFFFFFF Flash: 0020:88BBFFFFFFFF Flash: 0020:88BBFFFFFFFF Writing Done Finished, time used: 180 sec Remove/Install battery now ! |
The Following User Says Thank You to f164 For This Useful Post: |
Problem with new benq S660 : Error: UNKNOWN FLASH CHIP: 0020:88BB | gsmnice | FuriouS II | 1 | 11-04-2004 02:48 |
