11-05-2007, 11:40 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: repair shop Age: 44
Member: 181825 Status: Offline Thanks Meter: 199 | benq siemens A38 unloking error getting following error while unlocking a38 COM2 selected Device: BenQ A38 Checking data, wait... Action: Unlock Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Flash: 0001:227E221D2200 Err: not locked or unknown eeprom Check Parameters Fail Finished, time used: 94 sec Remove/Install battery now ! |
05-08-2008, 08:46 | #3 (permalink) |
Freak Poster Join Date: May 2007 Location: jammu
Member: 506395 Status: Offline Thanks Meter: 48 | benq siemens a38 problem i have benq siemens a38 unlock problem when i write eprom A38_repair_eeprom_0A[1].6BE its ok but nobody call me i call any body if i write any of other its say correct int sim card please help what i do i already flash it |
05-08-2008, 08:59 | #4 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: JSR, BD
Member: 310155 Status: Offline Thanks Meter: 1,313 | Quote:
whats type lock of ur phone ????? is it phone lock or SP lock ???? Err: not locked or unknown eeprom i think its phone lock. use this code 20010903, 83152746 by input key-board.................. post resualt thanks reaz. | |
05-08-2008, 09:03 | #5 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: UAE
Member: 420857 Status: Offline Sonork: 100.1576793 Thanks Meter: 1,734 | Quote:
yes bro you are right, i agree with you thanks | |
05-08-2008, 09:04 | #6 (permalink) | |
try to write this epprom...................................... | |
05-26-2008, 07:10 | #7 (permalink) |
No Life Poster Join Date: Jul 2007 Location: UK Age: 45
Member: 553000 Status: Offline Thanks Meter: 2,302 | regarding A38 benq siemens unlock method COM2 selected Device: BenQ A38 Checking data, wait... Action: Unlock Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Flash: 0001:227E221D2200 Err: not locked or unknown eeprom Check Parameters Fail Finished, time used: 94 sec Remove/Install battery now ! when u see that kind of error then flash with simple eerpom file |
Benq-siemens A38 Unlock Solution Needed | francogsm | NON Siemens Brand (ODM Phones) | 14 | 07-07-2012 10:30 |
20 Dec 2006: BenQ-Siemens A38 model supported, M100 unlock added | InfinitySupport | Infinity-Box | 28 | 05-03-2007 08:32 |
New benq siemens a38 unlock? | to_deal_with | VygisToolbox | 14 | 03-24-2007 20:26 |
unlock benq-siemens a38? | samirr | FuriousGold | 1 | 01-13-2007 15:25 |
BenQ-Siemens A38 (and other). We want to buy this phone sp-locked | InfinitySupport | Infinity-Box | 7 | 11-08-2006 22:18 |
