Old 10-16-2008, 05:53   #1 (permalink)
notgood's Avatar
Member: 355635
Thanks Meter: 53
BenQ Siemens C30
BenQ Siemens C30 dead phone succes revive by infinity
iff don't have right cable for c30 just use infinity pinfinder to find the right pinout .... see the log
==== log opened: [10/14/2008 7:08:49 PM] ====
Application: C:\Program Files\InfinityBox\PinFinder\PinFinder.exe
Initializing...
software version: 1.14
Smart-Card S/N: 2143
Smart-Card firmware version: 0111
Initializing PinFinder...
Initializing database...
base database version: 01
user database version: 01
Loading configuration...
Initializing cable list...
Initializing platforms...
Initialization finished
COM7 ready
searching adapter at COM7...
adapter found, version: 2000
Serial No: XXxxxxXXXxxxXXXxxxxXXXxxxXXXx
done
Initializing...
done
Cable: 1x8 (L8A)
cable type: 1x8 (L8A)
platform: MT: MT6205, MT6217-MT6228, MT6230
pins: 8, plain
power cycles: 1
activation cycles: 7
power-off delay: 20
start Rx/Tx: 1/1
Initializing...
Press and HOLD phone Power button now !
detecting pins...
19200 fixed
CPU: MT6225
result: Rx:2 Tx:4
time required: 5 sec
and this is log flashing c30 with infinity software
==== log: [10/14/2008 7:14:42 PM] ====
COM7 [VCP0] selected
Device: BenQ-C30
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: write NOR flash
"smart write" active
"format ffs" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
Boot...
19200 fixed
Connecting, wait...
Initializing[6225:8A03:8A00]...
CPU: MT6225
chip: 0001:E803:000E
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:18A59F00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is damaged, recalculation required
identification#1 detection finished
device-id: BA746846
identification#1 protocol ver: 04
ver. sw1: CKT25_06B_PCB01_GPRS_MT6225_S00.MARCH_BENQ_L3EN_21 0_071102_LY3_SIV100_SA75_CTF_FM.BIN
ver. sw2: MARCH_BENQ_L3EN_210_071102_LY3_SIV100_SA75_CTF_FM, B865CAC9
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading: eeprom[CKT25_06B_PCB01_GPRS_MT6225_S00.MARCH_BENQ_L3EN_21 0_071102_LY3_SIV100_SA75_CTF_FM.BIN]...
file saved: C:\Program Files\InfinityBox\MModule\eeprom[CKT25_06B_PCB01_GPRS_MT6225_S00.MARCH_BENQ_L3EN_21 0_071102_LY3_SIV100_SA75_CTF_FM.BIN]_20081014-191845.B0E.bin
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
security area (code #1) calculation...
done
Area: Firmware
flash: EC257E25082501:18E59F00000000
Write: Firmware
Write Done
Finalization...
formatting...
flash: EC257E25082501:5959A800000000
Finalization Done
Finished, time used: 1402 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
After flashing don't forget do repair imei... this the log
==== log opened: [10/16/2008 11:44:40 AM] ====
Application: C:\Program Files\InfinityBox\MModule\MModule.exe
Loading data, wait...
[Infinity Box] v2.35
S/N: XXXX:xxxxxx
Wait...
Device: BenQ-C30
Done
==== log: [10/16/2008 11:45:17 AM] ====
Action: imei
imei write method: mode-2
imei write channel: imei #1 for dual sim/mono-CPU
new imei: 357199010542776
Model: BenQ-C30
19200 autodetect
CPU: MT6225
Connecting, wait...
Phone detected, wait...
warning: wrong packet cs
Hardware: MT6225,E03
Date: 2006.06.14
Version: 1.0
Version: MARCH_BENQ_L3EN_205_070919_LY3_SIV100_SA75_HTF_FM
Version: CKT25_06B_HW
44 byte(s) read
imei: 13579024681122
warning: current phone imei is incorrect !
It's need to repair imei for correct phone functionality !
connection Ok
44 byte(s) read
verification...
verification done: 35719901054277
Finished, time used: 8 sec
THX to infinity team for great job
regards
notgood
The Following 3 Users Say Thank You to notgood For This Useful Post:
Old 10-16-2008, 08:15   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Thank you very much for test report !
Each test report with attached logs is very important for us so we can see how is Infinity-Box
software works and what is possible problems and successfully done work.
Old 01-24-2009, 21:01   #3 (permalink)
sharmin's Avatar
Member: 222009
Sonork: 100.1576751
Thanks Meter: 435
good information
ok will try and post result , still now I cant be able to alive any benq c30 by flashing with infinity or spiderman
I dont understand what is the correct procedure !!!
Old 01-24-2009, 21:23   #4 (permalink)
Member: 130995
Hello,
Just write flash.
How to write flash (upgrade/downgrade firmware, change language):
1. connect cable from box to device
2. run "Infinity-Box Shell" software
3. select required model
4. run required software module
5. select required model (if need)
6. go to software "Settings" page and select COM port
7. go to software "Flash" page and load required files
8. press "Write" button and follow instruction given by software
[07-10-2008] Siemens & BenQ-Siemens : now 3 Credits UnlockBase.com UnlockBase 0 10-07-2008 09:51
I need soft for Unlock Benq Siemens C30 ua9cee NON Siemens Brand (ODM Phones) 4 07-01-2008 07:32
All Siemens, BenQ Siemens Pinouts Request [Only Here] shahzaadbutt NON Siemens Brand (ODM Phones) 4 05-27-2008 17:51
all siemens/benq siemens sp and user codes! Mr.Exlusive Main Sales Section 0 03-16-2008 12:08
Page generated in 0.19158 seconds with 10 queries
