Old 01-07-2010, 20:51   #1 (permalink)
lasfar's Avatar
Member: 75223
Thanks Meter: 62
Best alcatelbox
I just started this thread to say that infinity box is the best in alcatel now : i tried s303x ,220X ,280x,363x and ot708x unlock without flash smoothly
thank you infinity team
wbr
The Following User Says Thank You to lasfar For This Useful Post:
Old 01-08-2010, 09:39   #2 (permalink)
Member: 572191
please, i need ot103x good firmware. i'm try downloaded from support but i got no service after that. plese support help! more question, can i flash read firmware from onotherot103x to this phone? how?
Old 01-08-2010, 09:44   #3 (permalink)
Registered User
Member: 46135
Thanks Meter: 28
best box
ofcourse infinity is the best.. we need all updates infinity team thanks and keep itup
Old 01-09-2010, 17:26   #4 (permalink)
lasfar's Avatar
Member: 75223
Thanks Meter: 62
here is one successfully unlocked log of OT708
Release Power button now !
Boot Done
====> Initialize ...
flash: 98006F00000003:09EA0000000000
flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader (chip) is present: 00020000
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is present
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.14943 487.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_B94589A2].rpl
rom info detection finished
TCL-ID detection...
TCL-ID detection done
device-id: 14943487
rom info ver: 07
sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN
project-id: MAUI.08A.W08.40.SP1.V32, A28945B9
code offset: 00020000
ffs offset/size [01]: 01800000/00800000
TCL-ID identification
version: 16D
provider: 708X-2ARGES1
customization: CN16CD28
customization: XN16CD28
TCL-ID identification done
TCL-ID is present
ffs/eeprom address assigned: 01800000
startup code area #1 check...
startup code area #1 fixed
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
product id: JRDHUIZHOU_MT6225_OTMINI_SERIES
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
searching sec info#2...
search sec info#2 finished
sim-lock status: enabled
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#3...
search sec info#3 finished
area1 is valid
area2 is valid
area3 is valid
area4 is valid
number of sec info areas: 3
security area (sec info, part #2) calculation...
error: security area (sec info, part #2) header is invalid
security area (sec info, part #1) calculation...
..................security area (sec info, part #1) detecting size...
security area (sec info, part #1) detecting parameters...
security area (sec info, part #1) encoding...
done
Write: security area (sec info, part #1)
security area (sec info, part #1) calculation done
identification header detected
customization name adjusted
Write: security area (sec info, part #2)
security area (sec info, part #2) calculation done
done
done
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
original imei: 00000000000000
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-708X,708A_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_0 8A_W08_40_SP1_V32__system_log_14943487_B94589A2_20 100109-205222.B0X.bin
Finished, time used: 3 min 55 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 01-11-2010, 19:29   #5 (permalink)
Member: 572191
thanx infinitysupport for ot103x firmware update in your support. now my phone work perfect! if i want flash another phone with backup firmware, how i must do?
Old 01-11-2010, 20:03   #6 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
It is possible to restore back eeprom/ffs files without additional files conversion.
It is not possible to restore full flash files to avoid permanently dead phones.
If you have full flash backup file and want to restore it:
1. Check support area, probably required file already exist there
2. If required file is not found send a mail with the next information to support:
- reason to send files
- full text from phone back label
- flash backup file
We will check your files, prepare and upload good flash files in support area ASAP.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 08-08-2010, 14:02   #7 (permalink)
Member: 520110
Thanks Meter: 44
Yes i think infinity is the best for Alcatel know keep working
we waiting for s211 new boot
600 pieces waiting
The Next Best Thing (?????) (Box packing, VCD) (USA) (Hong Kong Version) IPMART ipmart WebShop 0 03-29-2010 18:10
The Next Best Thing (?????) (Box packing, DVD5) (USA) (Hong Kong Version) (Region 3) IPMART ipmart WebShop 0 03-29-2010 18:10
Which one is the best Nokia flasher box, best updates, best support, best working gsm-traders Nokia Digital Core Technology 4 ( DCT-4 ) 117 02-22-2007 17:21
Cruiser is the best-best-best-best-best team Berikarević SonyEricsson (USB-Smart) 1 08-21-2006 23:24
Purchasing AlcatelBox-OT311,OT511 vidas Main Sales Section 2 03-08-2002 15:14
Page generated in 0.17885 seconds with 9 queries
