07-01-2008, 04:23 | #1 (permalink) |
Freak Poster Join Date: Oct 2006 Location: Indonesia
Member: 368629 Status: Offline Thanks Meter: 87 | Beyon B555 Maybe got some bugs Here is the Log: COM24 [VCP1] selected Device: Beyond-B555 Checking data, wait... Action: flash write Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 00BF:7353 Connecting Done Check hardware... sw version: ULC2GL 0 A 0 q Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\Beyond-B555_eeprom-sta_20080701-101127.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\Beyond-B555_eeprom-sec_20080701-101259.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\Beyond-B555_eeprom-complete_20080701-101311.B1E.bin backup critical area Done Check memory... Check memory Done Write... Erasing: Firmware error: erase failed: 00400000 Write Failed Finished, Remove/Install battery now ! Time used: 190 sec |
07-07-2008, 11:46 | #2 (permalink) |
No Life Poster Join Date: Aug 2004 Location: E.A.P & E.A.S
Member: 76239 Status: Offline Sonork: 100.1584414 Thanks Meter: 210 | Me too have same problem : COM3 [VCP0] selected Device: Beyond-B555 Checking data, wait... Action: flash write Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 00BF:7353 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: E:\Program Files\InfinityBox\Pana01\Beyond-B555_eeprom-sta_20080707-173815.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: E:\Program Files\InfinityBox\Pana01\Beyond-B555_eeprom-sec_20080707-173818.B1E.bin reading [eeprom-complete]... file saved: E:\Program Files\InfinityBox\Pana01\Beyond-B555_eeprom-complete_20080707-173825.B1E.bin backup critical area Done Check memory... Check memory Done Write... reset... done Erasing: Firmware >>>> stuck at 42% need solution from Infinity Team .... thanks |
Today i got new bug module not open.... | sahil2000ind | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 11-15-2009 15:56 |
hi sir i got some sets when i try to format i got flash erase error | unlock_solution | Infinity-Box | 4 | 09-21-2009 12:05 |
NEW samsung software got next BUG !! G600 flashing not work, D880 too | wgmmmx | HWK | 1 | 06-10-2008 22:43 |
~~~ Check here , u maybe got u need ~~~ | .::Gsmdenis::. | Main Sales Section | 0 | 01-18-2007 19:32 |
7110 motors, anyone got some spare?! | logosunlimited | Main Sales Section | 2 | 05-04-2002 05:55 |
