12-10-2008, 08:02 | #1 (permalink) |
Junior Member Join Date: Sep 2007
Member: 578626 Status: Offline Thanks Meter: 7 | Beyond B555 dead trying to reset setting but no luck.. after that i try to flash firmware but erasing error.. now the phone is totally dead. anyone can give solution? thx be4... ==== log: [12/10/2008 1:57:47 PM] ==== COM7 [VCP0] selected module v1.57 Device: Beyond-B555 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... slowest Set Baud Done Connecting ... flash: 00BF:7353 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... backup critical area Done Check memory ... Check memory Done Write ... Erasing: Firmware error: erase failed: 00400000 Write Failed Finished, time used: 26 sec Remove/Install battery now ! |
12-10-2008, 14:27 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Try to select model Digibee-BSNL-G200CF and try to flash phone again. What is the results ? |
12-10-2008, 19:00 | #3 (permalink) |
Member: 578626 Status: Offline Thanks Meter: 7 | thanks for your support... now i can flash it with no error but the phone still dead... do you have any other solution,please... ==== log: [12/11/2008 12:34:18 AM] ==== COM7 [VCP0] selected module v1.58 Device: Digibee-BSNL-G200CF Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00BF:7353 Connecting Done Check hardware ... sw version: .00 ULC2GL 0 A 0 q Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-static_20081211-003434.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-security_20081211-003435.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-complete_20081211-003441.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_lock-area_20081211-003447.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 34 sec Remove/Install battery now ! Loading file v.04... Beyond-B555_2007-Dec-27_fw_lp.B1M.bin loaded Loading file v.02... Beyond-B555_eeprom-static_01.B1E.bin loaded ==== log: [12/11/2008 12:37:46 AM] ==== COM7 [VCP0] selected module v1.58 Device: Digibee-BSNL-G200CF Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00BF:7353 Connecting Done Check hardware ... sw version: .00 ULC2GL 0 A 0 q Check hardware Done Check parameters ... Check parameters Done backup critical area ... backup critical area Done Check memory ... unlocking... lock found operation done Check memory Done Write ... reset... done Erasing: Firmware Writing: Firmware Erasing: Firmware Writing: Firmware Erasing: Eeprom Writing: Eeprom Write Done Finished, time used: 436 sec Remove/Install battery now ! Loading file v.02... |
12-11-2008, 06:01 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If flashing was done but phone can not power-on I think you have a reason to open phone and check it's hardware, especially because before flashing phone hang on startup. |
How to Flash Beyond B555?? | ansarsossok | Infinity-Box | 0 | 06-06-2008 12:18 |
beyond b555 errror on boot | mentari | Infinity-Box | 7 | 05-27-2008 10:32 |
Beyond B555 Can't Read Flash or any Operation | torpedo_seluler | Infinity-Box | 1 | 05-25-2008 07:11 |
beyond b555 can't boot | Andra | Infinity-Box | 1 | 05-23-2008 21:15 |
Beyond B555 .:: Infineon e-gold ::. | m_amien | Infinity-Box | 2 | 05-13-2008 10:34 |
