Old 02-04-2009, 17:20   #1 (permalink)
Member: 771601
Thanks Meter: 10
pinfinder not detucted rx tx whats problem??
plz help..........
(or more) and repeat operation (parameter "Finder activation tries")
software version: 1.16
cable type: 1x8 (L8A)
platform: MT: MT62xx (autodetect)
searching adapter at COM5...
adapter found, version: 2000
pins: 8, plain
power cycles: 1
activation cycles: 7
power-off delay: 20
start Rx/Tx: 1/1
Loading configuration...
Initializing...
Press and HOLD phone Power button now !
detecting pins...
failed to detect pins
time required: 27 sec
Power Off !
Set parameter to value 20 (or more) and repeat operation (parameter "Finder activation tries")
Cable: 1x8 (L8A)
Power On !
platform: MT: MT6205, MT6217-MT6228, MT6230
pins: 8, plain
power cycles: 1
power-off delay: 20
start Rx/Tx: 1/1
Initializing...
detecting pins...
Power Off !
plz help team & useres why this problem i m new & whaat is set parameter to value 20 all phones & working phones plz help
Old 02-04-2009, 20:34   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
first of all you must make sure that you have mt62xx MCU phone.
you either can do this by disassembling phone or by typing *#0044# and pressing green (send) button.
if you will see "language set: english"- you can be sure, that this phone is MT62xx
second: connect phone to box power and try to power it ON.
if it does not power On- you must modify main infinity box (remove diode)
and might be need to add capacitor to pinfinder output.
both procedures are available in pinfinder user manual.
third: you must press power button and hold it all the time while program search pinout.
please check if all steps are correct in your case
Old 06-07-2010, 19:29   #3 (permalink)
Member: 518978
Thanks Meter: 9
sir i have same problem ...
I also remove dide & make jumper.., 1000 mf 6.3v cap.but same problem..
software version: 1.20
cable type: 1x24 (L24A)
platform: MT: MT6205, MT6217-MT6235
searching adapter at COM23...
pins: 24, plain
power cycles: 1
power-off delay: 20
start Rx/Tx: 1/1
Initializing...
detecting pins...
time required: 107 sec
Trying to Power-On...
Power On !
but some phone pin findin well..
see this log...>
pins: 8, plain
power cycles: 1
power-off delay: 20
start Rx/Tx: 1/1
Initializing...
detecting pins...
19200 fixed
CPU: MT6223
result: Rx:3 Tx:4
time required: 11 sec
Power On !
Old 06-07-2010, 20:35   #4 (permalink)
sudsud's Avatar
Member: 420318
Sonork: 100.1661057
Thanks Meter: 65
hi bro
some phones rx , tx are inside the board , open ur phone and check it inside
Old 06-07-2010, 20:39   #5 (permalink)
Member: 1203577
Thanks Meter: 24
yes really it's very hard now the work with pinfinder i dont know why not infinity team slove this problem he cant detected any mobile and i have trust in infinity team if i can advandced he can fixed all the problem for us let wait what he can do for us infinity team you are great and i hope you give great work for pinfinder
Old 06-08-2010, 18:27   #6 (permalink)
Member: 518978
Thanks Meter: 9
hi bro
Helow brdr..I chek the 6300i bords.. and i find rx,tx in a systom conector.. & my friend have a spider man box.it can find rx,tx within 5 scnd... i dont no what's problem..!
Old 06-08-2010, 19:30   #7 (permalink)
Member: 148515
hello!
lets start from beggining.
when you connect power wires to phone,
run pinfinder software,
can you power On phone from pinfinder power?
for this you must select cable type and press "Power On" button in software
Old 06-08-2010, 20:07   #8 (permalink)
Member: 518978
Thanks Meter: 9
i tryde many times sir...& with soldering rx,tx wires. ..!
Old 06-08-2010, 20:38   #9 (permalink)
John(LMT)'s Avatar
Member: 507536
Thanks Meter: 75
Same Problem IPF can't detect any Phone
Hello @Supporters i have the same problem. My Pin Finder doesn't detect any phone, with an Alcatel 303 (for testing) on hand and the right procedure (as i read in FAQ) i modified my Infinity Box (using the specified Jumper), with a multimeter i check wires have 4.9V, but phone is never detected eather if i set manually the correct pinout no luck. What more can i do to use it please?
Thanks In Advance!
Old 06-09-2010, 12:51   #10 (permalink)
Member: 1203577
Thanks Meter: 24
yes sir i agree with you i hope infinity team do something for us because it's the time for he tested her pinfinder he must update her fw for detected the new mobile plz infinity team with usbfinder spider man i can detected anymobile ut with pinfinder i must solder and i waist time for nothing ....you are great team do something for your pinfinder software
Old 06-09-2010, 18:18   #11 (permalink)
Member: 148515
Thanks In Advance!
hello!
there is also small chance that pinfinder itself is defective.
if you sure that you doing all correctly- i think best way is to send it to reseller for testing
Old 06-09-2010, 18:52   #12 (permalink)
John(LMT)'s Avatar
Member: 507536
Thanks Meter: 75
Solution Needed.-
hello!
@Support, thanks for your fast reply but could you assist me deeper please, (what more can i test) because since i purchased i haven't ever been able to use it, (months) and send it back to the reseller would be too expensive.
Thanks in advance.-
Old 06-09-2010, 19:00   #13 (permalink)
Member: 1203577
Thanks Meter: 24
infinity team plz your test with your self with new china mobile he cant detected any rx and tx you must fixed the bug that's all
Old 06-09-2010, 23:12   #14 (permalink)
John(LMT)'s Avatar
Member: 507536
Thanks Meter: 75
Hey bro i don't think it is a Software Bug, mine is the Infinity Pin Finder hardware, because SW runs normally, so i would like to know which components to check to be sure hardware has malfunction.-
Old 06-10-2010, 15:38   #15 (permalink)
Member: 1203577
Thanks Meter: 24
yes bro he must update her fw for detected the new pinout like usbfinder for spider man
BESTEL 5000+ I can not find rx tx on the socket on the motherboard or the phone Master911 Chinese Models & Cloned Phones 0 12-02-2009 16:37
ve pro not find rx tx b.t.basheer VE-PRO BOX 1 02-23-2009 03:24
super doctor Mtk cable Rx Tx define problem genius2005 Chinese Models & Cloned Phones 1 01-22-2009 14:08
help: pinfinder cannot detect RX TX MARK26 Infinity-Box 5 10-02-2008 02:42
MC-TOOL Not found RX TX rashel.com MC-Tool 0 04-06-2008 13:46
Page generated in 0.26225 seconds with 9 queries
