02-12-2009, 08:37 | #1 (permalink) |
No Life Poster Join Date: Jul 2007 Location: Dubai, UAE Age: 38
Member: 547967 Status: Offline Thanks Meter: 653 | Big problem in Kg270 Unathourized Sim Infinity team i search all posts but could'nt fine perfect solution i have 2 Pc's of Lg Kg270 with unathourized sim mean when i put sim of any carrier it shows unauthorized sim this is not Black List. but unable to solve this problem plz tell us good Solution to solve this kind of problem Operation i done Unlock all 3 methods Flash Two firmwares+Lp+FS+Eeprom Reset Settings Write Imei manualy It's Imei is 35030526000000400 Plz Infinity give us good solution Thanxs. |
02-12-2009, 09:06 | #3 (permalink) |
Freak Poster Join Date: Mar 2008 Location: I Don,t Know Age: 38
Member: 718939 Status: Offline Thanks Meter: 90 | also chack your sim jacket,may be you found some different falut i mean may be probem in sim jacket Last edited by HAMMZA_MOBILES; 02-12-2009 at 09:15. |
02-12-2009, 09:14 | #4 (permalink) |
Member: 547967 Status: Offline Thanks Meter: 653 | thanxs for all to help BUT PLZ READ MY POST CAREFULLY THEN ANSWER coz i changed Imei but same @Hamza_Mobiles will u told me how repair this kind of phone with Infinity tell me rest of my Option don;t tell me again that Operation which i Did Thanxs |
02-12-2009, 09:24 | #5 (permalink) |
Member: 547967 Status: Offline Thanks Meter: 653 | @Makkah_Mobile Thank you so much ur Idea works for me i was wrong in module i have 1.60 but when i download 1.61 it works again thank you so much. PROBLEM SOLVED TOPIC CLOSED Thanxs |
02-12-2009, 09:31 | #6 (permalink) |
No Life Poster Join Date: Apr 2007 Location: SL3 LBF IN Kamoke(Gujranwala)
Member: 481915 Status: Offline Sonork: 100.1604233 Thanks Meter: 476 | repair imei back from phone all will be done. i solved many times, cause: we write eeprom downloaded from support have imei default (35030526000000400), this # is blocked by any person, so we must have to repair other one from back of phone. nothing else no worry brother |
02-12-2009, 09:34 | #7 (permalink) |
Member: 718939 Status: Offline Thanks Meter: 90 | bro, 1.type 2945#*# and do facory reset i solve this problem many times with this procedure 2.repair imei if is need otherwise ignore because i also solve this problem with infinty 3.chack it hardware ,may be simjacket is faulty or a pin these 3 oprations repaet and then tell us what happen |
05-20-2009, 13:42 | #10 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | Quote:
chenge imei set shuold be ON for this process | |
Big big big problem in g502 | mahdy4 | Sony Ericsson | 1 | 06-28-2009 12:10 |
big problem in S1 seereeus in SE | askaralikp | Universalbox | 4 | 02-14-2009 18:48 |
big big problem in support area............... | foufou34 | HWK | 23 | 10-31-2008 05:40 |
BIG PROBLEM IN 2 in 1 dongles | ::.::HITGSM::.:: | Wray´s Products | 6 | 01-17-2005 18:49 |
