06-30-2008, 23:23 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: Earth Age: 49
Member: 237984 Status: Offline Thanks Meter: 71 | BIG problem with nokia6300 i flash phone with this firmware T6226_05C_PCB01_GPRS_MT6226_S01.A7_NOKIA_U1_NOBAHA SA_V06042.BIN same case phone dead support pls help me |
06-30-2008, 23:31 | #3 (permalink) |
Member: 237984 Status: Offline Thanks Meter: 71 | log COM9 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:1D8C:B350 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.CB2A07DA.[T6226_05C_PCB01_GPRS_MT6226_S01.A7_NOKIA_U1_NOBAHA SA_V06042.BIN_BC9C251B].rpl identification#1 detection finished device-id: CB2A07DA identification#1 protocol ver: 04 ver. sw1: T6226_05C_PCB01_GPRS_MT6226_S01.A7_NOKIA_U1_NOBAHA SA_V06042.BIN ver. sw2: A7_NOKIA_U1_NoBAHASA_V06042, E4DA6343 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 01227E22202200:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00EC0000 Detected eeprom/ffs address is non-standard: 00EC0000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00EC0000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 00140000 ffs chip: 00 eeprom/ffs area: 00000000:00EC0000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[T6226_05C_PCB01_GPRS_MT6226_S01.A7_NOKIA_U1_NOBAHA SA_V06042.BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[T6226_05C_PCB01_GPRS_MT6226_S01.A7_NOKIA_U1_NOBAHA SA_V06042.BIN]_20080701-010412.B0E.bin flash: 01227E22202200:29EA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished security area#1 calculation... done file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_CB2A07 DA_T6226_05C_PCB01_GPRS_MT6226_S01.A7_NOKIA_U1_NOB AHASA_V06042.BIN_BC9C251B_20080701-010444.B0X.bin Area: Firmware flash: 01227E22202200:29EA0000000000 Write: Firmware detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Write Done Finalization... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_CB2A07 DA_T6226_05C_PCB01_GPRS_MT6226_S01.A7_NOKIA_U1_NOB AHASA_V06042.BIN_BC9C251B_20080701-010457.B0X.bin Finished, time used: 498 sec Remove/Install battery now ! |
07-01-2008, 15:21 | #8 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: Somewhere there Age: 14
Member: 567723 Status: Offline Thanks Meter: 314 | Quote:
1-Full erase ship 2- flash eeprom with this eeprom file Get It 3- now flash your phone with any fw + eeprom (from support ) 4- if dont work reflash eeprom with this file : Get It NB eeprom and flash file must be the same version alll done no dead phone br >>> GsmFreeShop <<< | |
07-01-2008, 15:40 | #9 (permalink) | |
Member: 237984 Status: Offline Thanks Meter: 71 | Quote:
i will test that and post the Result | |
07-01-2008, 18:37 | #10 (permalink) | |
phone alive again | |
big problem with my mx key | sshreesai | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-31-2010 10:07 |
big big big big big problem with server | software zone | FuriousGold | 1 | 01-16-2008 17:25 |
big big big problem with lurker!!! | Bugytech | Wray´s Products | 9 | 11-23-2004 08:55 |
BIG BIG BIG Problem with DCT-3 and UFS3 | PhonePlus | UFS2 + UFS3-Tornadoflasher | 7 | 09-03-2004 09:50 |
BIG BIG BIG problem with SPC2 and VKLAY | wael_nasreddine | E-Gold Based Phones | 2 | 12-22-2003 22:23 |
